need help hooking V8 Rad to 6 cylinder f100
RE 1065 F100 I'm sure I am not the only one who has done this, and probably someone may actually have the part number and name of the radiator hose I need. I have taken a 65 F100 V8 radiator and put it into the same that has a 6 cylinder, the V8 radiator has the water pump connection on the drivers side BUT the 6 cylinder water pump is on the passenger side, ANY help appreciated on the actual part number and brand of hose I need to hook up the radiator, if you have used such and it is for a different vehicle altogether please give me the info I need to get this thing on the road.
Thanks
Thanks
I suppose it is too late, since you already have the radiator you wish to use, but I have found that a good radiator shop can build you anything you want, in any package you want, and for a very good price. The could probably even take the end cap off your radiator and put on on it that matches your application.
A long-assed radiator hose does not sound like an ideal solution.
Suggestion and your comment for fix
Thanks for your suggestion, I recently put a aluminum Rad in one of my 65s so I took the rad that was in and put in the one with a six, no need to waste a good rad, what I did was get a part from Summit that has a male end on each ends a a petcock in the middle, I used this to join 2 flex hoses.
52 USCG Panel
30
04-21-2019 05:38 PM
Eston Newbern
10-11-2010 04:39 AM
