special procedure for removing fuel rails
Old 10-07-2010, 07:01 PM
stooks's Avatar
stooks
stooks is offline
Does anyone know if there is any special procedure to removing the fuel rails on a 2003 Ford F150 4.6L engine in order to get to the spark plugs? Need to change a plug and trying to do it myself but have never done so before.
Old 10-07-2010, 07:15 PM
jgeese's Avatar
jgeese
jgeese is offline
You shouldn't have to remove fuel rails to change plugs. Go to the top of this section, on the third item down it reads in bold red letters - Read First, 1997-2003 F-150 Frequently Asked Questions. You will find details for changing plugs in the 4.6/5.4 motors.
Hope this helps, it did for me...
Old 10-07-2010, 10:32 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
Unbolt and lift, might have to wiggle a little. Make sure to lube the O rings a bit when you put it back in.
Old 10-08-2010, 12:04 AM
stooks's Avatar
stooks
stooks is offline
removing ruel rails
Thanks guys you really helped me out a lot thanks for the info
fidge1
1999 to 2016 Super Duty
15
09-07-2011 06:35 AM
Bob7211
3.8 & 4.2L V6
09-13-2008 02:46 PM
NekSiwel
03-05-2008 12:35 PM
racenitro
16
04-30-2005 11:46 PM
jreid
Aerostar
03-09-2003 11:04 PM
Quick Reply: special procedure for removing fuel rails
