Help with info on 6.6L
I've got a 92 F600 project I'm working on and need a little help. I bought this truck wrecked. I ran it out of fuel while working on it parked. From what I've found out, it probably has air in the line. I'm trying to purge it with the hand pump above the fuel filter. All I got tonight was a sputter. Any suggestions on getting it going?
I'm interested in tech info on this engine, since I plan to have this truck for a while. Is there free info out there? If not, where do I find it?
John B.
John B.
If it has the two small fuel filters mounted on the intake manifold, open the bleeder screw on that assembly and use the hand primer pump till solid fuel appears there. Then close the screw and continue to use the hand primer pump untill its difficult to pump, secure pump plunger by screwing down finger tight. Attempt to start engine.
Thanks,
John B.
Looks like it'll be Saturday before I can get over to work on it.
I'll just be thrilled to get her cranking so I can start my build-up. This being my first diesel, I've got a lot to learn. I'll worry about the performance stuff after my builds finished and I got a few miles on her. I followed your link and read the post. It's good info.
Thanks,
John B.
Received 3,090 Likes
on
fill the fuel filter with diesel fuel or diesel kleen before you start pumping, and it will make your life a lot easier.
once you try to start it, keep the idle around 1000-1500rpm for about 1 minute, or until the engine runs clean with no sputtering. this will ensure you get all the air out of the lines. if you rev it too high before it fills everything up, you take a chance of running the filters dry before the mechanical fuel pump can fill them and purge the system of air.
Thanks again,
John B.
Jarrett Campbell
05-26-2017 09:07 AM
Nytefog
6.7L Power Stroke Diesel
09-12-2015 07:18 AM
jssparkyjr
05-03-2012 08:21 PM
