idle rough and white smoke
Old 09-30-2010, 11:43 AM
david gunnells's Avatar
david gunnells
david gunnells is offline
i have 1993 ford f250 7.3 IDI non turbo i ran it out fuel i had to bleed the injector lines to get it crank back up it ran well the next time i crunk it up it runs rough and blows lots of white smoke that smells rich this is my first deisel truck i really dont know what to do next so i really need some help thanks
Old 09-30-2010, 12:01 PM
rodneywar's Avatar
rodneywar
rodneywar is offline
let it run for a bit it should clear up
Old 09-30-2010, 12:09 PM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
Is it hard starting ??
Does it die after it starts ??
Does it clear up after a few minutes ??
FYI, Bleeding is done at the Schrader valve on the Filter head, it is unnecessary to crack injector lines, once the air is out of the system up to and including filter, the Injection pump will bleed itself in just a few revolutions of the motor.
-Enjoy
fh : )_~
Old 09-30-2010, 08:36 PM
david gunnells
Yesterday when i first bleed it did start smooth two hours later it started rough i bleed again it ran rough today i bleed again it ran rough then i noticed the hoses that connect the injecters was dripping fuel so i fixed that. now idles smooth and runs down the road smooth but while in park if i rev it up and let all the way off it goes died.it will crank right back up every time. it does not go dead coming to a stop though.
Old 09-30-2010, 09:58 PM
rupejosh's Avatar
rupejosh
rupejosh is offline
david gunnells welcome to FTE and the idi forum!!!!
lots of white smoke and rough running.....my first thought is air intrusion and after that injectors.does it have a slight knock?
Old 10-01-2010, 12:54 AM
pooch4428's Avatar
pooch4428
pooch4428 is offline
my son ran the gas out of my 1997 F250 7.3 Powerstroke i put gas in it and got in fired it up and tried to get home. It is missing and has no power even after a fuel filter change any idea?
Old 10-01-2010, 02:07 AM
ADTMan's Avatar
ADTMan
ADTMan is offline
Well, I would put diesel in it. Not gas. If you put gas in it, you will probably have to purge all the lines and go back with diesel. Yes change the filter also. Hope nothing else happened.
Old 10-01-2010, 09:35 AM
david gunnells
air intrusion huh it may have a slight knock =if so what does that mean? thanks for the welcome im already enjoying this site i really need to get this truck back on the road any ideas on how to tackle this air intrusion?
Old 10-01-2010, 12:49 PM
Festus Hagen
Methanoholic
Injector Return Kit Installation.
Injector Installation Kit
Many prefer to toss the o-rings in the kit (and I highly suggest you do) and use these Viton Return O-Rings - McMaster-Carr Item 9464K24, Viton is impervious to Diesel.
For the Injector Installation Kit installation You can follow Starmilts Humorous Fuel Return Replacement Procedure, I like to cut the 6 pieces between the Injectors to 4-1/16", Use a sharp razor blade to cut the hose and Vaseline to lubricate the o-rings.
For proper fuel system bleeding you can use steps 1 through 4 and 13 through 15 of the Fuel Filter Replacement.
-Enjoy
fh : )_~
Old 10-01-2010, 01:46 PM
david gunnells
i fixed it runs perfect now thanks i had one return line leaking. i took a razorknife and cut a inch off hooked it back up / no more air intrusion thanks for everything i will keep in touch
Old 10-01-2010, 01:52 PM
Festus Hagen
Methanoholic
If you don't do a kit, you'll chase your tail on them return lines ... Once disturbed, they just keep failing!
That is why Viton o-rings are recommended, they are impervious to Diesel and can take more heat, yet remain soft and pliable.
-Enjoy
fh : )_~
Old 10-01-2010, 01:57 PM
david gunnells
Ok thanks ill get the kit as soon as possible how much does one usually cost?
Old 10-01-2010, 02:15 PM
Festus Hagen
Methanoholic
The kit I posted above is about $20 + S&H.
The O-Rings I posted above are about $6 + S&H. (cost me $10.61 total)
Just under $40 all total ...
-Enjoy
fh : )_~
BigRed7.3l
07-14-2014 10:33 PM
fatkid89704
06-15-2014 10:22 PM
Legacy123
1999 to 2016 Super Duty
11-01-2013 02:50 PM
Rigormortise
60
04-30-2013 06:30 AM
429poweredf350
12-07-2010 09:39 PM
Quick Reply: idle rough and white smoke
