390 or 410
390 or 410
I recently bought a motor to replace my 352, the guy told me it was a 390 that was out of a 1967 Mercury Station Wagon. The motor was a orginal 4 barrel motor but it was changed to a 2 barrel carb in the past. How do you tell the differences between a 390 and 410 or any other FE by look without tearing the motor apart. I really don't know what I bought the block has a C6ME casting and the heads are C6AE-J and C6AE-L . I don't think the guy I bought it from would lie to me because he is a Preacher, but he is a Chevy guy and didn't know much about Fords. I would appreciate any help on this matter.
390 or 410
You dont have to tear the motor apart, just pull 2 spark plugs.
Put #1 cylinder on TDC, pull the spark plug and stick a long pencil or other such skinny rod down, mark it where it hits the flat by the hole. Put the rod in the #4 cylinder the same way, without turning the crank, and then measure the difference.
3 3/4" (3.78 stroke) is a 390, 4" (3.98) is a 410 (428 too).
Just out of curiosity, I've never seen a C6AE-L head, or even heard mention of one. I have a set of the C6AE-J's, but I would like pic's of the -L's, if there is any way you could take some it would be greatly appreciated!
390 or 410
Thanks FrayedSanity the help on how to identify a FE engine. I have not been able to do it yet because I sliced my finger to the bone while working on my motor, breaker bar accident. I will get a photo of the FE C6AE L head once the weather clears up and my finger heals, might be a few days.
390 or 410
Beer helps, I should have got stitches, I could see the ligament and bone when I did this. It didn't bleed very much, so I said the hell with stiches and put a band aid on it, still hurts 3 days later but no infection. I will get some pictures soon but I need to heal up a little, I can't hold much with the hand I injured my finger on.
Those breaker bars always hurt me, I should just get rid of the darn thing and stick to air tools, everytime with a breaker bar it never fails I hurt myself, oh well.
390 or 410
Word of advice I'ld never knew about before 3 days ago. Heat pads/Hot water bottles, warm espom salt soaks all speed healing by increasing the blood flow. And here I always thought heat was only good for sprains and bruises!
If you already knew this, then maybe someone else will benefit
Good luck opn the recovery!
390 or 410
That is a good point 427. Never thought of that. Most of the pistons have dishes and then a valve relief. You could still angle the wire to angle towards the outside of the cylinder so it against the wall.
Kinda funny but the only time I have ever had stitches was from getting cut by a cheap computer case. They had to put a few threads through the fingernail. That really sucked. It does lay you up for a long time though doesn't it.
Johnny Be Cool
02-04-2015 06:46 PM
HotRodRob
07-20-2013 04:19 AM
dc600slayer
11-02-2004 05:06 AM
xericx
04-05-2003 11:54 AM
