Expedition EL vs. Suburban
I am currently looking at a 2010 Expedition El with about 20,000 miles. I am also looking at a 2010 Suburban with about 4,000 miles. The Ford is about $6,000 less. Both are equipped similarly.
Did any of you consider a Suburban before purchasing the Exp? If so, what made you decide on the Exp?
I currently drive a F150 and have always had Fords so I'm comfortable and used to them. Just looking for some input. The Suburban has less miles and is 6 hours closer to my house.
It seems the Sub gets better gas mileage due to the 4 cylinder shut down.
Any advantages or disadvantages for either vehicle?
Thanks
Thanks
My sister in law has an '07 sub with the 5.3L and it's a gas hog. Likewise it has some engine issues inherent tot he 5.3L such as ticking and unexplained oil consumption. Their '09 Sliverado has the same issues.
There's no way to tell how the Expy was maintained and treated. Thank God for extended warranties and maintenance plans.
I was in the hunt for an Expy before I settled down to the F150. I found that the interior space (READ: leg room) was greater in the Ford. This to me is far greater of a pull than gas mileage, etc. I prefer the interior of the Expy over the Sub regardless.
I'm not a fan of the cylinder deactivation mainly because if you have more than 2 people in the vehicle, carrying a load, pulling a trailer, or you're not on flat ground, then the deactivation won't happen anyway.
I'm also a Ford loyal (3 Explorers and now my F150) so I'm biased anyway.
Someone I work with has a 2007 Expedition as well as an older one, I believe a 2001. Anyway, he says the 2007 does not tow nearly as well as the older one due to soft suspension. He also says the older one is better on a slick boat ramp because it has a limited slip differential, something no longer available on the Exp.
I prefer Fords and have owned 4 of them, but this is a tough decision.
Your coworker's info is a little off. I'm not going to say he's wrong, because each person's experience can differ from the next.
The newer Expy's are available with a limited slip rear end in the 3.73 ratio ONLY. They make a 3.31 ratio, but it's not available with LSD.
Make sure, if you're going to tow, that you find one with a towing package. The towing package is easily identifiable by a 4-pin AND a 7-pin connector. The 4-pin is on the left and the 7-pin is on the right, of the hitch. Also, the tow package will have an external transmission oil cooler. This small radiator sits in front of the main radiator. If you open the hood, you should be able to see it between the bumper assembly and the vehicles radiator.
It's my understanding that the new Expy's actually tow quite well. The 6spd tranny certainly helps this.
Honestly, don't rely on what we, or anyone friend might say about them. Go drive one, or many for that matter.
I drove a 2010 Expy EL XLT and LOVED it, but the wife didn't want to fork over that much $$ and we found a great deal on a 2006 F150 SCrew.
Please see the attached PDF about the 2010 Expy
I hope this helps.
I hope this helps.
The 2011 Expedition trailering guide isn't posted yet but the 2010 info is still there. The axle code for a LS 3.73.1 is H6. Nothing has changed between 2010 and 2011, even the 5.4L is still in service where as it has been eliminated from the F-150 line-up.
I would speak to the dealer about this.
Likewise when building the 2011 Expy EL, a limited slip axle is not available and only the 3.73 is being offered, at least in the XLT trim level. I didn't out the King Ranch. It could be different. Come to think of it, LS 3.73 may be available only in 4x2's. If you have a 4x4, it wouldn't really matter.
All the more reason to go find a 2010 RIGHT NOW!!!
Of the two, I'd get the Suburban, it's no worse of a "gas hog" than the Expedition.
Yup, the newer Expeditions have independent rear suspension, the regular Suburban will tow a little better while the 3/4ton Suburban is the clear choice if you plan to tow over 5k on the regular.
Expy's have had IRS since 2003. The Expy also has a 9200 lb tow rating with the max tow package.
If MPG's are the primary concern, then this class of SUV is not the right choice. Escapes and CRV's are built for that purpose.
I'm not super up to snuff on the Suburbans but I do know that they are plenty capable of getting the job done and they seem to last as well as the old Expy's.
I own a 2004 4x2 Expy and though I'll never get another as my family is shrinking, you couldn't give me free GM anything for it.
I'm on my fourth Expedition, the current one is an '07 EL Limited 4x4. Never had any problems towing with any of them. As far as driving, the '07 I have now has been the best driving vehicle I've ever owned. I compared the Exp and Suburban back in '07. Both are great vehicles but the fact that the Exp has a powerfold rear seat and independent rear suspension while with the Suburban you must remove the rear seat and store it somewhere made the Expedition the choice for me. I also think the interior has more room. As far as heavy towing the solid rear axle on the Suburban may help handling.
Towing any weight trailer requires a Weight Distribution Hitch. The Town Car suspension of our '07 Expedition XLT plus a WDH handles nearly 800 pounds of tongue weight and maintains a better ride than any pickup I've been in. Maximum towing capacity on our HD Tow equipped model is 9000 pounds.
Not sure what the problem on boat ramps might be, my boat isn't heavy enough to worry (and I don't launch my camper). I thought the standard Advance Trac traction control handled this. It sure does on ice. Tires make all the difference.
-- Chuck
-- Chuck
The towing capacity of the Suburban is 8100 lbs, that's 1000 less then the Expy, along with that issue and the rear power fold seats that you don't have to take out every time you need to haul something were the big selling points for me, I cant tell you how many times a week I fold the seats up and down to pick up kids or haul baseball and soccer gear to the games.
I tow a 33 ft Rockwood travel trailer that dry weighs at 5620 lbs, loaded up Id say its pushing 7000lbs easy, the Expy has pulled it fine for me, yes it has an independent suspension but I added a Helwig sway bar and that has help out a little bit. Im also towing on 22" ford wheels and that didn't hinder the towing anymore then the standard 20" wheels.
BTW mine is the non El version.
