I just dropped my old 360/np435 in today. The tranny was tough getting on but i believe it is on right. I had to back off the nuts on the rod for the clutch linkage and realized when i put the rod back on i couldnt see how far i had to go becuase the rod was blocking my view. Right now the tranny seems stuck in gear and i cant get it out. I started it up and i could start to get it to move but only way at the top of the pedal. My question is which way do i need to adjust the nuts to get my rod right? This might be hard to understand but just ask and i can try to clear it up. Thanks
Top plate on the tranny? it was off at one point but it shifted fine just moments before we went to put it in. When i went to put the shifter back on it looks as though its somewhere around 2nd gear. But regardless it doesnt want to move with or without the clutch in.
Alright il have a look. Is it most likely something within the tranny or something having to do with the clutch mechanism as to why it seems stuck in gear?
