1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2011 F250 actual weight
Old 09-14-2010, 08:33 AM
Biggziff's Avatar
Biggziff
Biggziff is offline
Has anyone scaled their F250/F350 diesel? I'm looking for the weight of a supercab, 4X4 diesel Lariat or KR, full of fuel. A buddy is having a garage built and needs to know the weight to spec the concrete and steel for the floors which will be over an open space. CAT scale data would be great! Ford says 6700 pounds, but my 05 V10 weighs 700 pounds more than that!
thanks
Old 09-14-2010, 09:13 AM
89LX306's Avatar
89LX306
89LX306 is offline
Test drive one and take it to a CAT scale. Then he'll know for sure first hand.
My 02 weighs 76XX with me and a half tank of fuel.
Old 09-14-2010, 09:24 AM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
Why not just tell him 10k and have it built to that? That way you're covered if you have material in the bed, etc.
Old 09-14-2010, 09:28 AM
senix's Avatar
senix
senix is offline
Received 1,418 Likes on 1,013 Posts
I would have it built to 10K myself. Mine 08 comes in at 8130 lbs with me and fuel.
Consider that he might have a load when he pulls in.
Old 09-14-2010, 09:29 AM
DAVE67FD's Avatar
DAVE67FD
DAVE67FD is offline
Yeah,
The floor spec. should be quite a fair amount over the vehicle weight anyway.
Old 09-14-2010, 09:34 AM
Biggziff's Avatar
Biggziff
Biggziff is offline
There is an engineered in safety margin, but he'd like to know what the truck weighs to assess what number to start with. The difference in cost to go from 7K to 10K is significant (steel and concrete) so having the correct data to start with is important. Yes, he can shotgun a guess and get it right, but the cost is huge!
thanks
Old 09-14-2010, 10:45 AM
Ace!'s Avatar
Ace!
Ace! is offline
About $10k different
Old 09-14-2010, 10:51 AM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
The only way to know the actual weight is to drive it over an actual scale. There are just too many variables. Regardless, I'd spec it to at least 10k. All he needs is to drive it in there once with a load in the bed and it'll cost him a lot more than the extra to build a better floor.
Old 09-14-2010, 10:55 AM
Thenewboss's Avatar
Thenewboss
Thenewboss is offline
2011 F250
6.2 Supercab
4x4 XLT
Longbed
Me 170LBS + Full tank of gas 35 gallons
7180
I have a weight slip in my console for the LEOs if I ever get pulled over. NC is very strict about their weighted tags. I don't know what kind of scale, but it is certified.
Old 09-14-2010, 11:00 AM
Biggziff's Avatar
Biggziff
Biggziff is offline
Originally Posted by Thenewboss
2011 F250
6.2 Supercab
4x4 XLT
Longbed
7180
Thanks, but you're running a gasser. Unless you know how much the diesel adds to the overall weight?
Old 09-14-2010, 11:02 AM
Ace!'s Avatar
Ace!
Ace! is offline
Per Ford specs it would appear the diesel weighs approximately 800 lbs more than the gas truck* (going by their published base curb weights). So, if you go by Thenewboss weight you'd be at approximately 8000 lbs but remember it depends also on the options. Not all Lariats or King Ranches will have all the same options (they'll have the options as part of the package but could have more or fewer overall options).
*For some reason in Ford's specs it fluctuates. The diesel adds ~600+ to over 800+ lbs in the same truck per Ford specs.
Old 09-14-2010, 11:03 AM
Thenewboss's Avatar
Thenewboss
Sorry, missed that part. I just got excited because I have any actual weight slip and not a guess.
Old 09-14-2010, 11:41 AM
Biggziff's Avatar
Biggziff
Biggziff is offline
No worries....thanks!
Old 09-14-2010, 12:52 PM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
if he builds it for 7,000 make sure that passengers only get in AFTER he has pulled out of the garage...
Old 09-14-2010, 07:14 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
i'd say use a figure of 8500lbs for teh truck.. better to be over the actualy weight as a starting point then under...
Quick Reply: 2011 F250 actual weight
