Well, after consulting with the Mrs. I am leaning toward either the 18th or 19th for my GTG. I am pretty sure I can make either of those dates. I need to put in my Tugger kit, ABS sensor, check for boost leaks, and I might try to swing buying new ball joints for the passenger side and get that hub looked at and fixed up. Not sure if all that can be done at once but I would like to try.
I know Troy offered up his shop but I would like to keep this closer to home if possible because every nickel counts right now. Not sure if Mike or Dave are available to host? If not I will take up Troy on the offer if it is still open.
I thought the 19th most of us were going to the renaisance festival in Shakopee. The Tobers were the ones that got it going. I believe that Sat is open.....
