Truck jerks while driving
Old 09-08-2010, 06:33 PM
muggsy93's Avatar
muggsy93
muggsy93 is offline
OK, I need help. My 93 F150 4X4 4.9L 5 speed will jerk while accelerating. Runs fine at idle even when reving. Replaced fuel filter. Only happens in low end of gear and high end, mid range runs OK. I'm at a loss. Don't know exactly what to check. O2 sensor is bad but has been running a while with check engine light on. Help?!
Old 09-08-2010, 06:48 PM
fordman41291's Avatar
fordman41291
fordman41291 is offline
I have the same issue, is it just like kinda random? Im thinking it maybe be possibly the fuel pump??
Old 09-08-2010, 07:02 PM
muggsy93's Avatar
muggsy93
muggsy93 is offline
It started off random, now it's starts just about a mile down the road. I also was thinking fuel pump or the fuel pressure regulator.??? Love this truck it's been good to me but don't want to dump a lot of $$$ in it.
Old 09-08-2010, 07:10 PM
fordman41291
yeah I know what you mean I only had to dump around 200$ in mine between Rad and new shocks in the front I am about to get it lifted after BCT..... maybe its that emergency fuel shutoff? that ford has I have no idea where its located you can still download the manuals for these trucks. at Fords Fleet web page.
Old 09-08-2010, 07:11 PM
fordman41291
hey Muggsy93 do you have an IM of any type?
Old 09-08-2010, 07:23 PM
Maniac's Avatar
Maniac
Maniac is offline
I was first thinking spark plug wires. Then you said it was after driving a mile. That means the problem is not happening when the truck is cold and not paying any attention to the sensors. Which leaves the sensors. You say that you know you have a bad O2 sensor. Did you do the test of the O2 sensor or did you just pull the codes? If it is just the code then run a functional test of the O2 sensor and if it is bad then replace it and clear the codes by disconnecting the battery for half an hour.
Old 09-08-2010, 07:25 PM
fordman41291
my truck istn throwing any codes...
Old 09-08-2010, 07:26 PM
muggsy93's Avatar
muggsy93
muggsy93 is offline
Doubt that it's the shut off or it wouldn't run at all. I'm way over what the truck is worth or as I like to say I've got a $5000, $1500 truck. As for IM I don't really like to give that info out on the net. Having said that I'm not that computer savy.
Old 09-08-2010, 07:28 PM
fordman41291
ahh ok, well just didnt know i usually talk to alot of my forum friends on IM ive made some good friends on the OB web page...
Old 09-08-2010, 07:30 PM
muggsy93's Avatar
muggsy93
muggsy93 is offline
Maniac - plugs and wires are new. Took it to AutoZone and had codes checked, told me it was o2 sensor. I'll try doing a function test tomorrow and see what happens.
Old 09-08-2010, 07:47 PM
fordman41291
hmmmm well mine does it but it aint throwing any codes... whats that thing that you fo Key on Engine off and key on engine on or something like that that you can do for Ford vehicles???
Old 12-26-2010, 12:27 PM
muggsy93's Avatar
muggsy93
muggsy93 is offline
Update if anyone is interested. It was the distributor. Finally had to take it to a shop, took them a week to figure out, first they thought it was computer replaced it with a used one no difference. He finally guessed that it must be the distributor. Good news they could return the computer.
Old 12-26-2010, 12:37 PM
timbersteel's Avatar
timbersteel
timbersteel is offline
Hey Muggsy93! Congrats on the Update!
I hope that everyone can Post their good news or bad news relating to their problem!
Thank you for sharing!
Old 12-26-2010, 02:04 PM
planehunter's Avatar
planehunter
planehunter is offline
Hey Muggsy93, did they have to replace the complete distributor, or just the electronics inside? What did it cost you?
Old 12-28-2010, 11:24 AM
muggsy93's Avatar
muggsy93
muggsy93 is offline
Had to replace the whole distributor, wish I would of thought of that cause I could've done it myself for just the price of the distributor. But it didn't cost that much, just under $200. Now I have a bad headlight switch and no dash lights but with half the dash removed and it being way too cold out and don't feel like haulin' wood in I think I'll wait a bit to finish.
Quick Reply: Truck jerks while driving
