Cruise Control Problem/1992 F250 4X4 S-Duty LB
I have to push brake pedal twice to disengage cruise control is there a fix for this? Or a recall? I just bought this P.U. recently so I don't know the history of said Truck. I am new to forums, not new to vehicle repair.
I would appreciate any info. Thank You.
The cruise control recall was for '93 and above trucks. The '92 and below do not use the same type of cruise de-activation switch as the '93 and above that are prone to causing fires.
My '92 F350 takes a pretty good push on the brake pedal to get the brake light to come on as well as deactivate the cruise. The brake on/off (BOO) switch is a goofy setup. I replaced that as well with no real improvement in the response to pushing on the brake pedal.
Thanks
Stuckinthemuddd
1999 to 2016 Super Duty
04-02-2015 12:49 PM
ford9303
04-30-2014 10:21 AM
