6.2L V8 Discuss the 6.2L V8
6.2L with 3.73 or 4.3 thoughts
Old 09-04-2010, 05:12 PM
fw2500's Avatar
fw2500
fw2500 is offline
I'm looking to buy a 2011 F250 crew cab short box with the 6.2L gas engine. I have a 10,000lb 5ver that I will be pulling 4,000 miles a year. Most towing will be around Minnesota but plan on taking one trip a year out to and through the Rockies. The remainder of the driving will be around 'town' and freeway empty. I wanted to get thoughts on whether I should get the 4.3 or 3.73 axle. I would like to get the mpg for most of my driving but I also want to get the 5ver through the mountains.
Thanks
Old 09-04-2010, 10:16 PM
ranger56528's Avatar
ranger56528
ranger56528 is offline
I dont tow to much,a boat,pontoon,atv's and a 5th wheel so I went with 3.73 but if I was towing more then 50% of the time I would of went 4.3............My last trip empty I got 16.0 mpg........
Old 09-05-2010, 06:00 AM
5 Star Tuning's Avatar
5 Star Tuning
5 Star Tuning is offline
Former Vendor
Hi fw2500
First Welcome to FTE! Thanks for posting up.
I suggest getting the 4.30 gear set with these 6.2L. With the new 6 speed trans with the extra gear (6th) rpms will be low enough to get some good economy out of the 6.2L.
Also be sure to check Fords 5ver specs between the 3.73 and 4.30 as i think there is a good amount of difference in weight capacity.
3.73 is around 12,000 lbs and the 4.30 is around 15,000 lbs
Old 09-05-2010, 09:23 AM
fw2500's Avatar
fw2500
fw2500 is offline
Thanks for the reply's. Fordmdb, I've seen that you've reported getting 16-18hwy and 12-14city with your 4.3 axle (even with the heavy foot you seem to have [I've seen the video] ). Ford56528, I believe you have the 3.73 and have seen 12-14 in town. What have you seen hwy? I saw someone reported 15-16city and 16-18hwy with the 3.73. If these numbers are more widely seen, seems with the size of camper I have, I just as well go with the 4.3 given mileage doesn't seem to be impacted much.
Old 09-05-2010, 09:31 AM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
i cant report mpg. but i can say i've driven both in a super cab 4x4 and the differance is vey noticable.
the 3:73s will still roast the tires off a stop light if you arent careful, but the 4:30s are downright awsome! throws you back in the seat pretty good. i'd say if it was me i'd go with the 4:30s just for the fun factor. but the fact you will tow i'd say go with them.
Old 09-05-2010, 03:31 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
just go for the 4:30's now..
you'll kick yourself later if you dont...
Old 09-05-2010, 07:30 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
+1. Go with the 4.30s. I have a 14k 5er on standby that I'll eventually be pulling with the new 6.2. Will probably only pull 5-10 times a year but I know I'll appreciate the gearing on those tows. Not to mention I like mash the throttle at times, which will make that 6.2 feel even more powerful.
Old 09-05-2010, 08:35 PM
ranger56528
This is what I got on my last trip running 3.73 and empty....
Old 09-06-2010, 09:15 PM
claycomotrucks1991's Avatar
claycomotrucks1991
claycomotrucks1991 is offline
Mine is a 3.73 and tows a 30ft travel trailer just fine.
Old 09-07-2010, 09:21 AM
Byram's Avatar
Byram
Byram is offline
I've got 3.73 & Pull some - My weights vary but I pulled a heavy gooseneck @ 17K last month for about 1000 miles & the 6.2/6speed even with the 3.73 did great. That being said - with the 6 speed having 5 & 6th over the 1:1 ratio I think that 4.30's would be just as good for economy. Maybe even better in city driving. If you drive highway primarily & less city the 3.73 might edge out the 4.30s but as soon as you hit the city streets the 3.73 will lug just a bit eating your economy..
Just my opinion....
Old 09-07-2010, 11:12 AM
Front Runner's Avatar
Front Runner
Front Runner is offline
I find myself locking out 6th gear when I'm in the city just to keep the engine from lugging, and changing gears.
Old 09-07-2010, 12:54 PM
fw2500's Avatar
fw2500
fw2500 is offline
So from others experience, would you agree that the difference in fuel economy between the 3.73 and 4.3 is only 1mpg? In searching around, this seems to be what people are saying. I'm not sure I've seen any definitive answer to that (nor do I expect to see a definitive answer given the variables that go into it). With a 10K 5th wheel, would I generally get better fuel economy towing with the 4.3(assuming similar conditions)? I'm inclined to go the 4.3 if the mpg is typically only a 1 mile or 2 off the 3.73.
Old 09-07-2010, 01:09 PM
Byram's Avatar
Byram
Byram is offline
My area has lots of foothills (Central Texas) also since I got the truck the A/C has been blowing full blast... My city /hwy average has been about 12.. Most of the post that I have seen here are more than that and most of them were running 4.30's.. Also I have a slightly larger than stock tire which would lower my 3.73's maybe to the 3.55 range (just a guess)..
Also my truck odometer loses about 1 mile per 17 according to a GPS... (that would make for a little worse milage as per the computer..
For example - real world... I reset the Ave Miles Last week - Straight highway showed 15 miles a gal after 43 miles - turn on the county road about 4 miles later the computer read 14.3 - then idles while I open gate about 2 minutes - it said 14.1 - eased up 1/2 mile ranch/caliche road - the computer read 13.4 mpg..
I would think that the 4.30's would have help out the slower speed stuff..
Old 09-09-2010, 12:00 PM
dunbar15's Avatar
dunbar15
dunbar15 is offline
How do you lock out 6th gear?
How do you lock out 6th gear, put it into tow/haul mode ? I have a 7.3L right not but ordered a 2011, on my 2000 I can shut off overdrive, wondering how to do it on the new truck, I know you can also run it in manual but if I can lock out 6th gear in auto that would be nice.. Thanks for any info on this..
Old 09-09-2010, 02:18 PM
Byram's Avatar
Byram
Byram is offline
Yea, When you are in Drive there is a rocker with a "+" &"-" if you hit them once it displays the 6 gears (1,2,3,4,5,6) if then you hit the minus sign it takes out 6th hit minus again it takes out 5th etc all the way to 1st --
Quick Reply: 6.2L with 3.73 or 4.3 thoughts
