Remote Key Fob Programming
Old 09-01-2010, 04:56 PM
repguns's Avatar
repguns
repguns is offline
Hello all,
Just swapped the 08 Limited for an 08 Limited EL! The EL only came with 1 aftermarket remote start fob. I still have one OEM fob from the other truck and am wondering how to program it for the new one. I know how to do this on GM vehicles, but not on the Ford. Any help is greatly appreciated!
Old 09-01-2010, 05:27 PM
repguns's Avatar
repguns
repguns is offline
Figured it out - cycle the key on and off 8 times. THe locks will engage once, then hit either lock or unlock on the fob you want to program.
Now if I could only program the extra remote start fob!
Old 09-01-2010, 06:11 PM
TIKT B8's Avatar
TIKT B8
TIKT B8 is offline
Old 09-01-2010, 06:33 PM
repguns's Avatar
repguns
repguns is offline
Thanks - but where is the programming/override button? I don't even think the old remote start fob (factory ford one) is compatible with the system on the new truck, which has a new fob for all functions. I think the new one is maybe the silver or Gold version.
Old 09-01-2010, 06:41 PM
TIKT B8's Avatar
TIKT B8
TIKT B8 is offline
Which one do you have? Those instructions should be for all systems (RMST and RMST/RKE/VSS).
<img src=http://grab.by/6c2f>
Old 09-01-2010, 06:48 PM
repguns's Avatar
repguns
repguns is offline
Top fob is from the old truck's system. The new truck's fob resembles a stock ford remote fob, with 4 buttons, lock, unlock, panic, start.
Don't take too much of your time for this, I just like playing with new toys!
Thanks much for your help!
Old 09-01-2010, 08:46 PM
TIKT B8's Avatar
TIKT B8
TIKT B8 is offline
I love playing with new toys also and I dont consider that wasting my time I just got my Gold system alarm/remote start installed last saturday so this is also a new toy for me.
The three pictures above are the bronze/silver/gold system fobs. I bought the gold and the third fob is what I have.
Old 02-10-2011, 06:39 PM
jd0245's Avatar
jd0245
jd0245 is offline
Hi, I have a 2010 Expedition that came with only 1 remote. No remote start on the vehicle. I would like to have a spare key/remote and I have found them for $50 online. Buy, does anyone know how to program the new remote to match the vehicle?
Thanks
Old 02-11-2011, 01:38 PM
repguns's Avatar
repguns
repguns is offline
JD - read the thread, programming is the second reply
Old 03-31-2011, 09:52 AM
SickPup404's Avatar
SickPup404
SickPup404 is offline
Hi all.
I also have had an issue where the Expy didn't come with fobs.
It's a 2007 Expedition EL Limited with the power liftgate. We bought the 5-button remotes figuring it just *had* to have the fob-operated liftgate.
I go through the programming procedure fine and all of the buttons operate correctly (door lock/unlock, panic, lift gate glass) *except* the power lift gate. Is there an additional procedure to get the power lift gate working, or is there possibly a fuse or other option that wasn't installed to enable this? The lift gate *does* work with the rear handle as well as the button on the dash.
TIA!
SickPup404
Old 05-29-2011, 08:40 AM
JayB07's Avatar
JayB07
JayB07 is offline
Gold key fob
Hey fellas, I just figured out where to find my keyless entry keypad code for my Expy on this forum, now a question about my key fob.
I have the gold version according to the pics above. I downloaded the PDF instructions for programming it and after a few reads I kind of figured it out except one thing. Where is the override button at?????
My remotes will lock and unlock doors and though I haven't tried it yet, I believe the panic button works. What isn't working is the blue remote start button and the "1" and "2" buttons which I believe are for the memory seats.
Any help would be greatly appreciated.
Thanks, Jason
Old 09-27-2018, 09:46 PM
dalesatter's Avatar
dalesatter
dalesatter is offline
SickPup…..I know this is an old post, but did you ever figure out what the problem was? I have the exact same issue with my 07 Navi, liftgate fob button does not work, otherwise all other buttons works as designed. I bought a new key fob and still the liftgate button does not work. Button on the dash and the pull handle works fine.
Old 09-28-2018, 07:01 AM
SickPup404's Avatar
SickPup404
Sorry, no help. I don't recall ever getting the liftgate button to work on the aftermarket fob.
We traded the Expedition on a 2011 Edge, so my memory is getting a bit fuzzy about it, but I remember two things that stuck with me because I couldn't solve them - the liftgate button on the key fob, and I never could find the factory door code sticker on the ECU in the passenger side foot well...
Best of luck!!
ride_red
2004 - 2008 F150
06-15-2015 06:22 PM
ktkoch
1997 - 2003 F150
02-06-2015 11:12 AM
LucasMN
1997 - 2003 F150
10-12-2012 10:36 AM
jerryrwoods
2009 - 2014 F150
12-17-2011 09:54 AM
mkac100
10-09-2009 07:35 PM
Quick Reply: Remote Key Fob Programming
