1978 - 1996 Big Bronco
89 big ford bronco
Old 09-01-2010, 03:27 PM
davidwalker4's Avatar
davidwalker4
davidwalker4 is offline
89 big ford bronco
i have an 89 302 v8 bronco. i need a vacuum diagram but, can't seem to find one. any help would be greatly appreciated.
Old 09-01-2010, 05:09 PM
greystreak92's Avatar
greystreak92
greystreak92 is offline
Welcome to FTE and the Big Bronco Forum. We will do our best to get you the most accurate info we can dig up.
The vacuum diagram is a rare commodity. Sometimes Chilton's will have a fair representation listed but that's about it. As for the vacuum portions of the EEC-IV and Thermactor system, this should be shown in the decal/diagram under the hood. Are you dealing with a completely disassembled vacuum system or just a portion of it?
Old 09-05-2010, 11:55 AM
davidwalker4
diagram has been removed
really need to know if there is a relay valve that controls the gas canaster filter and were is it located? thanks for your input. davidwalker4
Old 09-05-2010, 09:07 PM
greystreak92
There is a canister purge solenoid. Typical location is immediately to the left of the throttle body (looking at the engine bay from the front of the truck). It will have a two-wire connector and a small cylindrical body and be either clipped or tie-wrapped in place against the wiring harness. Earlier models may be mounted closer to the canister but locating it should only require following the vacuum line from the canister back towards the intake. This thread has a good picture of the solenoid.
