2.5 4 cylinder questions
Old 02-17-2003, 11:56 PM
mikeeep's Avatar
mikeeep
mikeeep is offline
Found what I was told is a 2001 Ford Ranger with auto and he says it has a 2.5 four cylinder in it. '
What can you tell me about the 2.5s? I read on here somewhere that they make 117hp
Were they reliable?
Can I ad a chip and maybe an cold air intake kit or something like that and see a boost in hp? Has anyone done this and what type of boost can I expect?
What about these little devices that trick your engine into thinking that it's always cold so it sends more fuel... do they actually gain any HP for you?
Not really wanting to add headers - don't want the additional sound.
Any comments about this engine or tranny or truck would be appreciated.
Mike
Old 02-18-2003, 03:36 AM
DainBramage's Avatar
DainBramage
DainBramage is offline
The 2.5 is essentially the same engine as the good old 2.3 Lima.
Just a little more stroke. As far as reliability, it's great. Very common to see em go 300,000 miles before a rebuild if maintained properly.
As far as performance upgrades, you're looking at an upgraded air intake, free flowing exhaust. Those will improve fuel economy, and give you some noticeable gains, hp wise. But, like you said, you don't like the idea of a loud truck. Oh, by the way, you already have a header stock.
Beyond that, you can upgrade to an aftermarket computer, from a few different manufacturers, and I've heard pretty good feedback on em, but have not tried one myself.
As far as the resistor installation to fool your MAF, don't waste your time, and $.12 (yes the $40 kits you buyfrom EvilBay are nothing more than a resistor from TandyShack.)
The biggest limiting factor you're going to encounter is the auto tranny, it just doesn't let the engine rev up into the RPM ranger you need to be in to get the most from your motor. Also, you might want to check you diff (can be checked on the tag inside your driver's door, and decoded using your owner's manual.)
About the best combination is the 4.10 (which is what I have).
Anything lower, and you will suffer off the line, and since you really can't go much faster than you can with the 4.10's, you may want to consider swapping if you don't have em already.
All in all, you're not going to get more than about 15 HP from all those mods, and that's about all you're going to get from a 2.5, without some serious $$$ and major build up.
In the case that that's what you want down the road, the most popular routes to take are swapping in a Turbo 2.3 from a 87-88 T-Bird (and a few others it appeared in), or a good old fashioned 5.0 V8 Swap.
Good luck!!!
Bird-Dog 250
11-15-2015 07:30 AM
Thudpucker
41
07-08-2009 01:46 PM
crapr6
17
08-26-2005 08:50 PM
Jerm
Modular V8 (4.6L, 5.4L)
18
07-15-2002 06:55 AM
Quick Reply: 2.5 4 cylinder questions
