1989 F-150 5.0 No Spark
Old 08-31-2010, 05:34 PM
ROD1234's Avatar
ROD1234
ROD1234 is offline
I have a F-150 4 x 4 5.0 L engine Automatic Trans. with no spark. I have replaced the coil and got a used computer for it. I checked all the grounds unless I missed some. At first I had spark and I used either then it would fire up for a couple seconds I replace the fuel pump and filter under the cab. Then after testing no spark from the coil. I have replaced all the sensors with used ones a few years back. Can anyone give me an idea what to check next. I have not taken it in for testing the computer and componants due to everyone wants an arm and a leg just to hook it up.
Thanks Rod
Old 08-31-2010, 06:35 PM
ymeski56's Avatar
ymeski56
ymeski56 is offline
Der Postmeister
Thanks Rod
TFI module (ICM) &/or PIP Sensor (Stator).
It's a good idea to replace the TFI (ICM) & the PIP (Stator) at the same time.Ford Fuel Injection Stator (RPM)
AZRogala
Computer Chips & Tuners
17
12-11-2015 04:30 PM
Thomas White
07-11-2015 01:25 PM
Grinder Man
10-10-2014 09:35 AM
trippn4re
23
06-02-2014 04:16 PM
doctorolds
06-01-2007 04:49 PM
Quick Reply: 1989 F-150 5.0 No Spark
