fuel saver
fuel saver
i didn't know if i should ask this in here... but what the hey....
does anyone have experience with devices like this and do they actually work or are they simply gimmicks?
http://www.sme123.com/fuelsaver.cfm
im doing an informative speech on surpressed technologies for saving fuel such as vaccum chamber carbuerators and whatnot, and came accross this product. any thoughts or opinions are appreciated....
fuel saver
i dont think the magnet separates anything out, i think it changes something with how the particles are flowing or how they volatize.... something to that effect. i know there's physics and chemistry involved which is beyond my education.... maybe someone who knows their stuff can add something
fuel saver
Dear friends
Just my 0.02
Theroretically it should work loading (+ and -) and spreading the particles in the fuel to be volatilized easier ence an easier combustion should happen producing a better fuel eficiency (not better than 0.1% due to other limitations on combustion process as such).
Practically it does not work since this porcess has to take the equivalent energy to a 1.5 million kw/h to produce such effect during 1 ms.
Therefore the theory behid this is real but in order to work it would take so much energy than you would have to carry on a nuclear plant in the bed just for getting 0.0X% fuel eficiency during just 1ms.
The only prooved fuel saver is a light load at the right feet.
This is a real snake oil
Just my 0.02
Regards
Ray
Just my 0.02
Just my 0.02
Regards
Ray
fuel saver
I have seen some web sights with ideas that seemed like they would work. One in particular seemed to trick your engine into running lean, hopefully with no harm--Try a search for "Eagle Research" on a good search engine. I have noticed that all of the low dollar mass marketed products don't usually do anything.
As far as milage goes, nothing beats good maintanance and a light foot.
fuel saver
Hmmm. I understood that the opposite was true - that it ran a bit rich so that there would be very little unburned oxygen (O2) in the cylinder, resulting in less ozone (O3, which oxygen likes to change to in high energy environments) production. The result is unburned fuel, which is changed by a catalyzed chemical reaction in the converter into less polluting substances.
That is my understanding, but then my understanding is often flawed.
fuel saver
too add what i know.....from what ive been reading on super high mileage carburators, they have no emissions since they literally burn almost all of the gas because it gets vaporized, and no unburned fuel gets put through the exhaust. what you end up with is literally no emissions, and air that is cleaner than some that you breathe. so it would go to say that if you burn rich, then your putting more unburned gas through, and your creating more emissions. if this is true, then the manufacturers would want to create less emissions, hence they would run their engines a bit leaner...... does this make any sense?
