Dana 70 rear axle
Old 08-29-2010, 05:03 PM
junks's Avatar
junks
junks is offline
Dana 70 rear axle
I Have a 1985 f250, 6.9L, Dana 70. Can I use a Ford rear axle in this truck. If so, what do I have to look for. Thanks
Old 08-29-2010, 05:11 PM
oreocreaming's Avatar
oreocreaming
oreocreaming is offline
by ford rear axle you mean sterling 10.25? either way yes, the u joints might be different size caps but other then that, your good to go.
Old 08-29-2010, 05:12 PM
oreocreaming
it is 2wd right? if its 4x4 you gotta make sure the gears match or when you do throw it into 4x4 your gonna bind up and break something
Old 08-29-2010, 05:28 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
Where is the fill plug located?
The Sterling axle looks a lot like the Dana 70.
Dana axle fill plug in the rear cover.
Sterling axle fill plug on the drivers side of the pinion on the front of the axle.
Old 08-29-2010, 05:34 PM
greywynd's Avatar
greywynd
greywynd is offline
Also, make sure everything in the replacement axle matches, spring perch to perch measurements and backing plate, to backing plates can also differ, depending if it came out of a dually, cab and chassis, or regular truck.
Dirtyweekender77
11-10-2013 07:51 PM
vettman
10-12-2011 09:33 AM
highway90
12-13-2005 10:31 PM
Wrecker
10-04-2004 07:14 PM
orange78oval
1978 - 1996 Big Bronco
01-25-2004 08:11 AM
Quick Reply: Dana 70 rear axle
