2004 F150 Passenger electric window
Old 08-28-2010, 06:48 PM
briank's Avatar
briank
briank is offline
Passenger power window will go down but not back up. I replaced the motor, it worked for a month and now it will not go up. Ford replaced the motor. Still doing the same thing. I have plugged the motor on the driver side and it works just fine. I am thinking that there is a wiring problem. Does anyone know where I can get a wiring schematic?
Thanks.
Old 08-28-2010, 07:43 PM
V10man's Avatar
V10man
V10man is offline
Have you checked the switches? Does it do the same thing with both switches? They are known for getting burned/dirty contacts.
Old 08-28-2010, 09:31 PM
Greg B's Avatar
Greg B
Greg B is offline
I also would suspect a switch bad. I have the same problem on my 06. The only time it's a problem is when the wife is riding with me and she rolls down the window and it won't go back up. I checked with the parts guy at my dealer and he told me that the passenger side is a little more $ than the driver side.
Old 08-28-2010, 09:48 PM
briank's Avatar
briank
briank is offline
It ended up being the main power window control (driverside control) switch, it has Corrosion on the contact. We are going to pull it a part and clean the contacts before we spend $70.00 at the dealership for a new one. What I found out is if while pushing it up or down, which ever direction is not working, if you hold it to the left while pushing the button it will work. Thanks for the reply.
Old 08-29-2010, 03:35 PM
V10man's Avatar
V10man
V10man is offline
Here is a good link on how to do that.
http://www.f150online.com/forums/art...ow-switch.html
Old 08-29-2010, 05:54 PM
briank's Avatar
briank
briank is offline
Thanks for the link.
Old 09-04-2010, 10:37 AM
yamaha500ml's Avatar
yamaha500ml
yamaha500ml is offline
Thumbs up Thank you
Cleaned the switches and my window works again, thanks for the helpful information!
Old 02-24-2013, 06:52 PM
lindazman's Avatar
lindazman
lindazman is offline
Thanks for the great post, it did the trick!! All four windows are working again.
Old 02-24-2013, 09:35 PM
seventyseven250's Avatar
seventyseven250
seventyseven250 is offline
Just used this info to fix a window switch. Was relatively easy. Only two problems:
1) The plactic tabs are pretty brittle, and they broke when I was prying it apart. Now it's all loose.
2) the little pins inside are worn down. So the dirty contacts are only half the story. I'm doing to go to the junkyard and see if I can find some more of those pins, I have a few bad switches, and if the pins are the only issue, I'll be in business for nearly free.
Old 02-24-2013, 09:40 PM
Ducky F150's Avatar
Ducky F150
Ducky F150 is offline
i have a 04 supercrew and the right rear window doest work as well as my power slider whats the chances the motors are bad or the switches
Old 02-25-2013, 06:38 PM
Greg B's Avatar
Greg B
Greg B is offline
It would be hard to say without checking things out. But the switches have been problematic in this generation of F150. I have yet to need to replace a motor, but I have replaced 2 of the switches in my 06 F150. I cleaned the contacts on my old switches for backup and thru them in the console.
Dpan63
04-09-2014 05:42 AM
andyman91
06-22-2013 01:31 PM
kyledallas
19
01-03-2012 04:42 PM
EdJones
1999 to 2016 Super Duty
09-04-2011 09:33 PM
mikren
1997 - 2003 F150
28
08-22-2009 09:39 AM
Quick Reply: 2004 F150 Passenger electric window
