1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
2008 Ranger,when to change Transmisson fluid\filter?
Old 08-25-2010, 03:00 PM
rootbeer's Avatar
rootbeer
rootbeer is offline
...............Ok , drove by trany shop and had them pull dipstick on trany , tech said fluid looks ...Like it had very few miles even though it has 27,xxx miles on the clock ! He also said they are recommending that the newer Rangers with Mercon 5 Wait too flush and replace filter till 50,000 miles ! Specifically , this applies too trucks NOT pulling trailers , and used mainly for highway commuting , which my truck is . Now , money is very tight so My plan is , after I review the comments on this thread I plan on buying 4 qts. of Mercon 5 each month and changing the fluid next spring which means I'll probably have around 35,000 miles on the truck . And , I plan on using the paw paw method too save some $$ . , thanks , rb
Old 08-26-2010, 05:53 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
Sounds like a timely & frugal use plan of funds to me!!!
Let us know how the filter change/ full fluid pumpout goes next Spring.
Be sure to opt for a really good tranny filter, like the specified Motorcraft/Filtran one.
Way to plan ahead & look out for your Rangers maintenance, when times are tough & funds are tight.
Old 08-26-2010, 02:37 PM
Danger_Dave's Avatar
Danger_Dave
Danger_Dave is offline
if you look at it this way, a newer vehicle these days you will be lucky to get 200k miles out of. so if you only have to do this 4 times, which is way more often than most people would, they only would change it if theres a problem. so if this prolongs the life of your vehicle and you actually get that 200k, or maybe 300k, then its money well spent. if you want to do the whole shibang every 50k, but a simple fluid exchange every 25k also then that would be even better. definitely keep documents and records of maintenance.
diyster
Escape & Escape Hybrid
06-01-2016 09:54 PM
Bulldog44
2004 - 2008 F150
08-14-2015 11:19 AM
powerstroker100
04-15-2015 09:52 PM
umgoblue86
03-13-2015 06:12 PM
Excurvelle
12-31-2014 02:09 PM
Quick Reply: 2008 Ranger,when to change Transmisson fluid\filter?
