Bad Master Cylinder??????
Old 08-25-2010, 02:54 PM
Bladely's Avatar
Bladely
Bladely is offline
Question Bad Master Cylinder??????
Ok I have a 1990 F-150. It sits most of the time. The other day I gave it a tune up and when I went to go for a ride, I lost the brakes, then all of a sudden they came back. They were not as strong as I think they used be. So I had my dad take it for a ride and it wouldnt do it for him then all of a sudden he went to slow down for a corner and the peddle went to the floor, hit the peddle again and they were back. So a long story short, is it the master cylinder or something else? Any Ideas?
Thanks
Old 08-25-2010, 03:08 PM
leavy20's Avatar
leavy20
leavy20 is offline
first check your fluid level. these trucks do have a valve that will block a blown line (not very well though) also check for fluid leaks. i would suspect a blown line before a master going out.
Old 08-25-2010, 03:10 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
Sure sounds like the master cylinder to me.... "Worn out cups/seals"
Old 08-25-2010, 04:53 PM
Ricache's Avatar
Ricache
Ricache is offline
Relatively easy to replace. Just did mine last month. Bench bleed the new MC before installation. Used a mighty vac at the wheels.
It's really cool to see new DOT3 fluid in the master cylinder reservoir for a change instead of that cola colored crap that was probably in there for 20 years!
Good luck.
Old 08-25-2010, 05:12 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
As long as there is no actual outside fluid leak I vote for the master cylinder. A bad RABS module will usually result in a soft pedal, not a complete drop to the floor.
If you are leaking fluid, start looking for leaking wheel cylinders in the rear or caliper pistons in the front as well as leaks in the lines/hoses leading to them.
Old 08-25-2010, 05:40 PM
Bladely's Avatar
Bladely
Bladely is offline
No there is no fluid leaking and all the lines look good, that was one of the first things i checked. Thats why i was thinking master cylinder. Now what is a RABS module, ive never heard of that before?
Old 08-25-2010, 05:56 PM
andym's Avatar
andym
andym is offline
RABS = rear anti-lock brake system
Sounds like the master to me as well.
Old 08-25-2010, 07:42 PM
jplinville's Avatar
jplinville
jplinville is offline
I'd check the vacuum line to it for cracks and such...before you start throwing parts at the truck.
Old 08-26-2010, 08:20 AM
rla2005's Avatar
rla2005
Cut from my Ford Service Manual:
Anti-lock brake control module (dual solenoid electro-hydraulic valve) located on the left frame side rail (5015) just behind the No. 1 crossmember.
Left frame implies driver's side of the truck. I just noticed your truck is a 1990. I am not sure when Ford introduced the Rear Anti-Lock Brake system. Yours may have the standard brake proportioning valve instead of RABS.
Old 08-27-2010, 02:00 PM
Bladely's Avatar
Bladely
Bladely is offline
Im thinking it does, it has the rear abs light that lights when you start it then goes out.
Hopefull saturday i can tear into it....was planning on it tonight but my job has bigger plans for me.....lucky me! LOL
JamesB128
1999 to 2016 Super Duty
07-25-2017 10:19 PM
johniebomb
06-29-2017 05:15 PM
Michaelmx
02-11-2017 10:38 PM
brian1080
07-28-2016 10:30 AM
cesspool
05-11-2010 10:11 AM
Quick Reply: Bad Master Cylinder??????
