Remote Start Car Alarm install help......
Hey guys, MY remote start car alarm should be delivered today. I am going to undertake this project myself with a friend or two. Unfortunately I have never done this before. Cant afford to have it installed, but need it (truck got broke into last week for the second time) So im sure it will have some sort of basic instructions, but i trust you guys on here more! Any help would be apreciated. i know i will need wireing diagrams etc...
Thanks for the help
Johnny
Thanks for the help
Johnny
1999 Ford F250 Remote Start System Wiring Chart
Vehicle Battery Positive Wire (+): Yellow
Vehicle Battery Positive Wire Location: Ignition Switch Harness
Vehicle Ignition Wire (+): Red/Black
Vehicle Ignition Wire Location: Ignition Switch Harness
Vehicle Second Ignition Wire (+): Gray/Yellow
Vehicle Second Ignition Wire Location: N/A
Vehicle Accessory Wire (+): Dark Red/Black
Vehicle Accessory Wire Location: Ignition Switch Harness
Vehicle Second Accessory Wire (+): Black/Light Green
Vehicle Second Accessory Wire Location: Ignition Switch Harness
Automobile Engine Starter Wire (+): Red/Light Blue
Automobile Engine Starter Wire Location: Ignition Switch Harness
Automobile Second Engine Starter Wire (-): N/A
Automobile Second Engine Starter Wire Location: N/A
Factory Anti-Theft System: Key Sends a RF Signal to BCM Module
Factory Anti-Theft System Type: Ford PATS Immobilizer Security System
Car Key Sense Wire (-): Black/Pink
Car Key Sense Wire Location: Steering Column Harness
Car Neutral Safety Wire (+): Red/Light Blue
Car Neutral Safety Wire Location: Ignition Switch Harness
Car Tachometer Wire (-): White/Pink
Car Tachometer Wire Location: Pin #48 of 104 Pin Plug at BCM Module
Car Speed Sense Wire: Gray/Black
Car Speed Sense Wire Location: Pin #58 at PCM Under the Hood on the Driver Side Firewall
Car Parking Lights Wire (+): Brown
Car Parking Lights Wire Location: At Vehicle Light Switch Harness
Car Brake Lights Wire (+): Light Green
Car Brake Lights Wire Location: At Switch Above the Brake Pedal
Car Reverse Lights Wire (+): Black/Pink
Car Reverse Lights Wire Location: At 12 Pin Gray Connector Below the Master Cylinder
Car Horn Wire (-): Dark Blue
Car Horn Wire Location: Pin #6 in Brown Connector Behind the Driver Dash
I am not sure on yours, but most you will need a bit writer to program.
thanks for the replies guys, I hope i am not biting off more then i can chew with this. This is the system I bought 2 Way Car Truck Security Alarm with Remote Engine Start Fits all Car and Trucks | Kapsco Moto
hopefully it will arive today. how will i know if i need a bit writer?
I put an auto starter in mine about a year and a half ago. No problems at all, I did need a few questions answered and guess what? Everyone here was more than helpful. i do recommend a few yoga classes before install though. Laying on the floor of the truck reaching up under the dash tends to cramp you up after a while...LOL
not gonna lie, I havent even started it. Its alot of wire and i am pretty nervous about messing it up. Think I might just find a profesional installer and let them do it. So right now the alarm is just sitting in my back seat. Probably gonna get broken into again and their gonna steal my alarm. Wouldnt that be something.
THAT'S Funny. But it would totally stink!
I know how I would feel!
No shame in doing research and making a decision to let a professional do the job. That's exactly what I did with my pinion seals. The more I learned, the more I realized there was 1 way to do it correctly or about 10 ways/things I might screw up and have to rebuild the rear. That could be the most expensive $190 I ever "saved". Found a local guy who's been doing it for 40 years and he got everything done perfectly.
JP
go to www.the12volt.com you can get the wiring diagram and it will tell you the location of the wires too
Robmullett
05-18-2013 06:31 PM
