ACC wire?
Old 08-16-2010, 06:29 PM
pathology knight's Avatar
pathology knight
pathology knight is offline
ACC wire?
i got one of those navitouch systems on ebay and am having a heck of a time with it.
right now, the biggest issue is the cd/dvd reader won't turn off when you turn the car off. It will only turn off if you manually turn the unit off. this is causing the battery to drain if you forget about it.
the manufacture said the problem is becuase of the cannbus system. Basically, they're no help.
i'm thinking that the way it's hooked up now, it's getting a 12v+ somewhere that won't allow it to shut off. Is there a ACC wire somewhere that i can hook up to this to turn it on/off with the car?
(2007 expy)
thanks.
Old 08-17-2010, 11:35 AM
berry1234's Avatar
berry1234
berry1234 is offline
Yeah, someone wired it wrong. It' should have a separate power wire that is connected to a 12v accessory wire that tells it to turn off when the truck is off. Did you install it? What wire harness kit did you use?
thewheelman
11-08-2016 08:49 PM
jefftb
1999 to 2016 Super Duty
10-07-2012 01:51 AM
bigfinn
27
03-03-2012 08:44 AM
bnb29
Electrical Systems/Wiring
22
08-25-2008 10:34 PM
Hit Man X
01-28-2003 12:27 PM
Quick Reply: ACC wire?
