2008 Expedition Rear Halfshaft Nut
Does anyone know what size is the rear Halfshaft Nut on the 2008 Expedition? I need to get a sucket but I cannot tell what size sucket I need. I have the Workshop Manual, but it doesn't tell me which size it is.
Thank you. That was a good confirmation. I used adjustable wrench, I squeezed it tight around the halfshaft nut, I pulled it out carefully and I measured somewhere around 35 and 36. I thought it couldn't be 34mm for sure so it must be 36mm. At least now I can go and buy the right socket. But the fun I think is just beginning, trying to figure out how to pull the hub out. I think I'll rent the hub puller from O'Reilly's.
As far as the "sucket" (socket) ... OK ... let's say spelling is not my strong side and I forgot to run the post through spell check.
But all I want to do is replace the broken studs and I'm trying to find the easiest way of doing it. One option is to get the Hub out. Another option is to get the parking brakes out without getting the Hub out. I've never done this before so I don't know which way would be better or easier, but something has to come out because there's no room for the studs.
Any suggestions would be appreciated.
