96 Vacuum Diagram
If you are referring to the vacuum diagram under the hood then go to Motorcraftservice.com, QuickGuides, VECI Labels. Use the pull downs to select the model year, model, engine, calibration code. I have found as long as you get the correct yr/model/engine you can pick just about any of the calibration codes to display the vacuum routing diagram.
idahocrewcab
01-12-2011 01:19 PM
