A/C upgrade
A/C upgrade
I am wanting to upgrade my entire A?C system on my 79 f150. The truck is a factory air truck that I am wanting to upgrade. Does anyone know where the best place to get all the components. I checked with NAP and the sale kits for trucks that didnt have factory a/c I want to put a whole new system in
Thanks
Thanks
The only thing you would need that they wouldn't have would be the factory style evaporator. Which wouldn't be hard to get some where else. But anyway, I know you'll be happy when you get the air going no matter where you get the parts from. I know I was. It's nice to be driving an older truck with the windows up when it's 100^ outside
If you still have your original York compressor bracket (or can get one from a junkyard) you can use this bracket from NAP to mount up a new Sanden style compressor. Which is what I'm gonna do if/when my York goes out. I've heard York's don't last too long after switching to R134.
York Compressor Adapter Plate / Universal Mount - Miscellaneous Compressor Mounts
Here is a complete kit with nearly everything but the evaporator, and it does come with mounting bracket too.
http://www.nostalgicairparts.com/air...orator-700.php
Just my .02 I'm done now. LOL
Nostalgic Air Aftermarket Air Conditioning For Automobiles and AC parts has a kit that includes EVERYTHING FROM the evaperator forward, condenser, compressor, engine brackets etc. specifically for our trucks. PN CK-1010 $559.99. This DOES NOT include the evaporator.
[QUOTE=jsutton;9190896]If you still have your original York compressor bracket (or can get one from a junkyard) you can use this bracket from NAP to mount up a new Sanden style compressor. Which is what I'm gonna do if/when my York goes out. I've heard York's don't last too long after switching to R134.
Will this bracket work for a straight compressor replacement? By that I mean, just pull the old York, bolt on the sanderson. Will the factory hoses and fan belt connect?
Will the sanderson compressor work\perform better than an old still working York?
Thanks for any info.
Not trying to hi jack the thread but to answer the question.
I really don't know if the new compressor would work better than a working York or not. I just plan on using one because I don't care for how much the York vibrates. You could use your factory hoses I'm sure, although I've heard that you need barrier hose so that the R134 doesn't seep out through the hoses. But you will need the high and low side R134 charge ports you can see I had a new low side hose made with a low side charge port built in. I got a high side hose from a newer truck and you can see in the pic I added an inline charge port. You can buy both high side and low side inline charge ports like that. Here is what my set up looks like.
