how much fluid does your torque converter hold?? and should I put fluid in it before I put it in place? and how much fluid do I need to fill an e4od... ??
The torque converter holds about 8 quarts. You don't need to fill it before install in the trans. The trans will fill it as soon as the engine is started.
