Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
03 Escape coolant leak
Old 07-18-2010, 08:33 AM
spdracer50's Avatar
spdracer50
spdracer50 is offline
Doesn't appear to be leaking from rad or any hoses or overflow tank,it leaks right out the bottom,it started as a slow leak,had to add coolant once every 2 weeks. now it's about once a week. As the budget for this repair is $0 right now,was wondering if anybody has ever used Rislone copper block sealer or any similar products with any success.Thanks
Old 07-19-2010, 11:47 AM
martin_csr's Avatar
martin_csr
martin_csr is offline
Have you identified where the leak is? Like, is a hose leaking, or is the thermostat housing leaking?
Old 07-19-2010, 12:17 PM
spdracer50's Avatar
spdracer50
I couldn't spot it anywhere,luckily I have a very trustworthy mechanic who found the leak and it's just a hose. Another bullet dodged.
Old 07-19-2010, 12:33 PM
martin_csr's Avatar
martin_csr
Did he show you the hose by any chance? And did he mention any other hoses that ought to be replaced. I replace stuff like that as a set, assuming they're originals.
PS: glad you got it fixed. That was an easy one.
Old 07-19-2010, 12:37 PM
spdracer50's Avatar
spdracer50
The only other one he noticed was a cracked pcv hose. Changing them all sounds like a good idea though, gonna do the ones I can get at myself.
BillC1009
16
08-07-2022 10:16 PM
Mickjman
12-19-2016 10:02 PM
Jesseprince717
10-07-2016 01:10 PM
Ricson
02-24-2012 06:53 PM
dbcrowell
09-17-2011 08:16 AM
Quick Reply: 03 Escape coolant leak
