GLOW PLUG LIGHT
GLOW PLUG LIGHT
O.K. I'M NEW TO THIS DIESEL THING.... MY GRANDFATHER LEFT ME HIS 1986 F250. I KNOW GAS ENGINES BUT VERY LITTLE ABOUT DIESEL. FIRST OF ALL DOES THE INDICATOR LIGHT ON THE DASH ALWAYS HAVE TO COME ON BEFORE YOU ARE SUPPOSE TO HIT THE STARTER? IT CAME ON IN THE WINTER BUT NOW IT DOESN'T AND THE TRUCK IS HARD TO START IN THE MORNING. IT HAS A 6.9 LITER INTERNATIONAL MOTOR WITH ABOUT 90K(?) ON THE CLOCK. DO I NEED TO REPLACE THE RELAY FOR THE STARTER GLOW PLUG? DROP THIS DIESEL DUMMY A LINE IF YA HAS ANY IDEAS...... THANKS HAWG OUT.....
https://www.ford-trucks.com/forums/9...old-style.html Have a read through this thread.
And yes the WTS light should come on before each start. First thing I would do is to use a test light to check each glowplug in turn and replace any that are bad, then see if the WTS light comes on.
on
***** The following assumes you have already checked cables, connections, cab, chassis and engine grounds. *****
***** That the water temp is below 112F degrees. (ie: cold motor) *****
***** When testing energize briefly, long enough to get the answer, no need to overheat things and no more than 10 seconds *****
Unplug the forward (towards front of truck) most connector on the Injection pump, this prevents overheating the FSS.
*** Glow Plug Test. ***
Test light test of the glow plugs:
Test that you get power to the glow plugs:
*** Pre '87 Controller, Relay test. ***
The relay is attached to the right (passenger) inner fender and has 4 terminals.
-Enjoy
fh : )_~
- Unplug the Glow Plugs.
- Attach one end of a test light to 12v+ battery.
- Touch the other end to the terminal on the end of the Glow Plug (where you unplugged the harness)
Does it light up?- Yes, Chances are it's good.
- No, Replace with Motorcraft/Beru ZD1A for 83-86, ZD9 for 87-94.5.
To do a positive test use a volt/ohm meter and test the ohms between the terminal and base. Should be .5 to 1 ohm resistance.
- Unplug a glow plug.
- Attach one end of a test light to the glow plug wire.
- The other end to ground.
- Momentarily turn the key on while watching the test light.
Does it light up?- Yes, test Glow Plugs.
- No, test Controller, Relay.
- 1 large terminal (Input Terminal) goes to full time 12v+. (battery)
- The other large terminal (Output Terminal) goes to the glow plugs.
- 1 small terminal (Power Terminal) is controlled 12v+ from the controller. (Purple wire)
- The other small terminal (Ground Terminal) goes to ground. (white with black tracer (I think))
Ensure there is 12v+ to the Input Terminal of the relay.
Ensure Ground is good, both the base and Ground Terminal.
Relay test:- Attach one end of a test light to ground.
- The other end to the Output Terminal of the relay.
- Remove the small purple wire from the glow plug relay.
- Momentarily apply 12v+ to the Power Terminal on the relay. (where purple wire was)
Does it light up?- Yes, relay MAY BE good.
- Test voltage at the battery and the Output Terminal on the relay while relay is energized. BE QUICK. (10 seconds or less)
- Voltages should be close to the same. If not replace relay.
- No, Relay is not working.
Controller test:- Attach one end of a test light to the relay Power Terminal (purple wire, do not remove from relay)
- Turn the key on while watching the test light.
Leave the key on until the test light goes off (or cycles) or 10 seconds which ever occurs first.
Does it light up?- Yes, The controller MAY BE good.
- Does it go off by itself? (It may cycle, thats good)
- Yes, Controller is good.
- No, The controller has FAILED ON ... Replace!
- No, The controller is bad replace.
-Enjoy
fh : )_~
GREAT THANKS
WOW. THANKS ALOT FOR THE INFO... I'M GOING TO TRY WHAT YA SENT ME AND SEE WHAT HAPPENS.... I HOPE IT'S NOTHIN' SERIOUS, MY GRANDDAD USED TO TAKE GOOD CARE OF HIS VEHICLES, I GUESS HE GOT SOME ONE ELSE TO DO IT FOR HIM AND THEY DIDN'T DO WHAT THEY WERE SUPPOSED TO. THANK YOU AGAIN. HAWG OUT...
on
compared to PS diesels,there's really nothing to serious that can happen to an IDI.even when a replacement engine is in need.1 single injector on today's diesels cost more than a good used IDI engine does.
your grandfather left you a nice truck.good luck bringing her back up to par
dang,Festus,your posts keep getting better and better as you cover more/add to them.nice job!
O, O.K. I usually just type. I didn't mean to seam rude. Uh, by the way "lose" not "loose" spelwing iz inpoten yu no. Just messin' with ya. I've every intention of restoring my grandpa's old truck. I have a 1985 Dodge p/u i've had since new, now it's being replaced with a newer 1986 ford f250. I'm going to visit our local classic car/truck lot (salvage yard) for a tail gate and parts, mine doesn't have one. Well I'm gotta go right now. Thanks again for the advise and all.... hawg gone....
Y2KW57
59
01-29-2017 01:44 PM
67camaro
15
07-09-2016 11:12 AM
Bill3753
21
01-22-2011 02:14 PM
