1988 f-250 7.5 Fi engine no start issue
I need help. Have a 1988 (built in 1987) f-250 7.5 L FI engine that will not start. Ran codes and got code 67 Park neutral switch open. Only problem is it will crank in park and neutral and not in gear. Both pumps are working and when I disconnected the line at the high pressure , filter side I was covered with gas. Blew through filter and it is clear. Both myself and a friend have tried to find the pressure test port, but it does not seem to be anywhere. Can anyone send me a picture or a diagram. truck ran and then would not start. thank you. robert walker
have fuel pressure
O.K. I found the test port and have pressure and flow at the fuel rail. I felt the injectors and could not feel them working, so something is stopping the signal from getting to the injectors. I have an Actron Elite AutoScanner Pro that does both OBD 1 and 2 codes. I scanned and came up with no faults. I had scanned a few days ago and it showed a park/neutral switch problem, but it went away. The battery is getting low so I am not sure if that can affect the scan. So what do I do next?
i hate to tell you this man but im still having problems. I do know if the ECM doesnt recieve the PIP signal then your fuel pumps and injectors wont work. This apparently is whats happening to my truck. I just need to find out why. If you figure this out please post how you resolved it
BigLar
BigLar
no spark
today I checked and found that I had no spark. Was assuming there was spark because when I sprayed starter fluid in the intake it seemed like it was going to start. Today I sprayed gas in the intake and no start. Then I checked the spark. So what would cause no injector action and no spart. Someone said a sensor in the distribuator.
When the ECM doesnt recieve a pip signal -No Spark- the ecm turns off the fuel pumps and fuel injectors. Remove a sparkplug #1 and with the plug in the SP wire ground the plug to some clean metal and have someone turn over the motor and look and see if the plug is sparking. This is the same problem im chasing right now. Ill LYK how it turns out when i get it fixed
BigLar
ndanielle1968
08-02-2015 08:22 AM
LTGregs
07-16-2015 07:26 PM
jinxie
05-11-2015 10:58 PM
kevin206
08-18-2014 11:05 PM
Two Lane Black Top
Performance & General Engine Building
08-04-2013 10:45 PM
