1994.5 7.3 and cruising rpms
Hi everyone,
brand new to the forum, but I've browsed lots before. Just retired my 1990 f250 with the 7.3 non-turbo diesel, and bought a 1994.5 f250 4X4 with the turbo diesel.
Axle code is 35, which I think means 4:10 gear ratio rear end. Trans. is 5-speed manual. Tires are wider than the stock recommended size, but are the same diameter (I measured). shouldn't affect speedometer/engine speed ratio, anyway, just ground speed.
Cruising RPMs at 100 km/hour (what's that, about 62 MPH?) in overdrive is close to 2500 RPM. To me, this seems high for a big turbo diesel. I was expecting it closer to 2000... maybe 2200 tops.
Do these numbers match what's expected for 4:10 gear ratio? Or did someone put a slow rear end in there at some point (there's been a few owners). I may think about gearing it higher, but I need to know where I'm starting from first!
Thanks very much and thanks also for keeping up this forum. I learn tons every time I visit.
Scott
Scott
I drive at 65 a lot, and its around 2200 RPM's with the same setup as the OP.
E4od has a taller overdrive than the 5 speed.
I have 33's for tires though also. Not sure if my speedo was calibrated. Last I checked it was still off.
Here is an easy way to figure out your rear end ratio.
Jack up the rear of the truck. (if you have an open diff, I think you have to leave one tire on the ground.)
Be sure to block the front tires, and put the truck in neutral.
Put a mark on the tire, and a mark on the driveshaft.
Spin the tire slowly, and count the amount of times the drive shaft mark goes around.
So, if you do have 5's in there, it will spin 5 times, and 4 times for 4, and with 3.55's it should be on the opposite side of the clock from where you made the mark originally.
Last edited by Talyn; 06-30-2010 at 02:35 PM. Reason: i'ma get this sentence right one of these edits.
Holy crap. I had no idea people spin diesel engines so fast!!! I got my first powerstoke not long ago, and I have a cow it spinning 1900 going 55mph. I guess I am used to big trucks, with 1800 ceiling rpm. When the thing shifts at 2400, i always cringe.
While on topic, kind of, do all of these truck tuners that adjust shift RPM just adjust for full throttle shift points, or do they lower part throttle shift points as well, also I would like the ability to lock out the downshift from over drive to 4th (E4OD) over 45 MPH (I tow a lot), unless I manually (shift lever button) call for a downshift. Is this possible??
and don't worry about the rpms, better to have lots of rpms and high hp then no rpm and lots of torque... torque doesn't do anything except add hp at the bottom of your rpm band, get out of the torque thinking
on
this is everything when it comes to moving a load.
this is why diesels outperform their gas equivalent when it comes time for work, because diesels have so much torque or "grunt" if you will.
think of HP as your momentum to keep the load moving,but its not the "force" / "grunt" that moves the load,thats the torque.when it comes to a "work" truck.torque means everything.HP keeps it moving along down the road.
Hey, Brutl_Force
When your pulling with these trucks you dont want to lug a load up hill at 1500 rpm. that will sky rocket EGT even on a stock truck. I'm not saying to redline it, just don't lug it. these trucks are most efficient between 1800-2400 rpm. this is where you get the most bang for your buck power and efficiency wise. I do know what you are talking about though about excessive downshifting !! that's why I went to the 5 speed manual.
