1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
'98 Expedition no forward gears, only reverse
Old 06-28-2010, 12:14 AM
RR515's Avatar
RR515
RR515 is offline
Question '98 Expedition no forward gears, only reverse
My '98 Ford Exp (5.4L) won't go forward, only in reverse. Just happened at the end of today while parking my trailer. Note: 1) I had just switched to 4wd in a gravel, slope area and (2) when I went back out later to fiddle with this problem, I can only go slow forward at very high rpm (should be spinning tires at this rpm). Very bummed and looking for some answers. I appreciate any help!!!
Old 06-28-2010, 01:31 AM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
If the fluid level is okay, then I'd say it's tranny shop time.
Old 06-28-2010, 10:55 AM
RR515's Avatar
RR515
RR515 is offline
Fluid is great. The problem occured just after switching to 4wd, so I was wondering if it could be an electrical short somewhere, like now its "stuck" in nuetral, not recognizing forward drive options. The dash shows AWD and 4WD options when I select them, but no forward motion. Is there a manual way to at least get it back to 2wd (with actual forward motion)???
Old 06-28-2010, 12:16 PM
alloro's Avatar
alloro
alloro is offline
The tranny determines forward and reverse, while the transfer case determines the 2H, 4H, and 4L options. Since you can get it to move in reverse, then the transfer case is transferring power from the tranny to the wheels; the transfer case is not the issue, the tranny is. However, if you insist on trying, the only way to manually shift to 2H is to remove the shift motor from the back of the transfer case and move the mechanism by hand.
Old 06-28-2010, 11:47 PM
RR515's Avatar
RR515
RR515 is offline
Many thanks alloro. I have a reputable shade tree mechanic coming out Wed morn...I'm sure he'll think come to your same tranny conclusion.
(The shift motor went out almost 2-years ago and wasn't cheap to replace. If the shift motor isn't functional, wondering if it could also render the car's forward gears useless?)
rpm9001
41
01-19-2024 11:30 AM
Late96
13
12-07-2015 07:55 PM
John Clugston
18
02-17-2013 03:23 PM
KJRevord92
1997 - 2003 F150
02-07-2013 07:31 AM
bobwhyte2002
1983 - 2012 Ranger & B-Series
02-24-2009 05:21 AM
Quick Reply: '98 Expedition no forward gears, only reverse
