'72 f100 brakes bleeding woes
Old 06-27-2010, 03:50 PM
Sparx Macgyver's Avatar
Sparx Macgyver
Sparx Macgyver is offline
Ok, tried to be descriptive with the title there, lol.
Basically, whats happening is I'm attempting to bleed my brakes. the problem is that 11mm is too big, 9mm is too small and the 10mm just slips on the bleer valve. I'm correct in assuming it's a 10mm, right? Every car I've ever done the brakes on has been a 10mm, even my old '76 280 Z I had.
Just trying to get the brakes bled so I can go for a nice ride and test'er out.
Old 06-27-2010, 07:12 PM
Sparx Macgyver
I've even tried deep well sockets. I don't really know where to go on this guys. I don't want to pay somebody to do it for me. There's no fun in it. Can't drive it without good brakes wither..
Back outside...
Old 06-27-2010, 07:22 PM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
I just put four new wheel cylinders in my Bronco a couple months ago. Went to bleed them and three were metric and one SAE or just the opposite.
Old 06-27-2010, 07:27 PM
Sparx Macgyver
Hmm. Thanks. I'll go try those. Thought I did, but I might have not..
Old 06-27-2010, 10:28 PM
Sparx Macgyver
Ok, I'm back. Still can't get the dag blasted things to loosen. Tommorrow I'll get some pb blaster and see if that will help loosen the things. But so far, nothing is working.
>_O
Old 06-27-2010, 10:47 PM
rebocardo's Avatar
rebocardo
rebocardo is offline
PB Blaster and a little heat (not from a torch) might help. A long time ago, I left a detailed technique for removing stuck bleeders.
Old 06-27-2010, 10:55 PM
Sparx Macgyver
Well, the thing is, I don't know if there stuck or what because I can't get any tools to grip the stupid bleeder's. That's my real problem. Tomorrw, I'll have light and will go look again, but as I said, weather or not there even stuck is yet to be determined. getting a socket or wrench to grip them is. Would it be logical to put a single strip of say gorilla or duct tape in the wrench to grip it? Just trying to think of what might help..
Old 06-28-2010, 07:20 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
Unless recently replaced the bleed screws should be SAE. Probably 3/8in. Use a six sided socket wrench.
Old 06-28-2010, 08:59 AM
Grubbworm's Avatar
Grubbworm
Grubbworm is offline
If nothing else, and if you round the head off for some reason, you could try using vise-grips and then replacing the bleeder screw with a new one.
Old 06-28-2010, 12:02 PM
merlynr's Avatar
merlynr
merlynr is offline
What lazyk said and go tightenand loosen easily back and forth, but only with proper six sided socket.(probably 3/8")
Old 06-28-2010, 05:07 PM
Sparx Macgyver
Ok, awesome! there not even stuck! I didn't have a 3/8 deep well socket, so I went to my local autozone and grabbed one. Works like a charm. Next question, can I remove the bracket around the front bleeders?
There's a bracket, and I think it just holds the brake line to the brakesin the front. Is it ok to disconenct this, bleed them, and reconnect it? I don't want to disconecet the brake lines, just that bracket, because I can't get any tools in there to get to the valve.
Old 06-28-2010, 10:05 PM
Sparx Macgyver
Ok, so, I can't bleed the front. Got the back done, cause I was following the usual order [RR, LR, RF, LF]. Back was rather easy. Though no air bubbles or debris, there was a llot of really nasty fluid coming out.
Old 06-29-2010, 07:09 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
Provided it is not the brake hose you can take anything you like off, including the caliper.
If you do take the caliper off (with hose connected) jam a block of wood or similar in so that the piston can`t extend and make sure you hold the caliper with the bleed screw at the top while bleeding it.
Also make sure you bleed fluid out of all the screws untill only clean fluid comes out.
cjben
05-13-2020 03:18 PM
SPreston2001
03-21-2020 05:04 PM
Turbo Dog
21
08-23-2019 10:55 AM
Curt750
12-17-2017 08:25 AM
john.johnson
02-01-2017 04:17 PM
Quick Reply: '72 f100 brakes bleeding woes
