ENGINE IDLES FINE,DIES WHEN PUT IN DRIVE
After you get to try it out you will be more able to diagnose the problem. Could be a fuel problem also. Enough fuel to idle but not enough to pull a load. I'll be interested to see if you can rev the rpm's up when in park or if the vehicle stumbles. Also lets hope it isn't a computer problem. Let us know more when you look at it.
Is the CEL lit???? if so pull & post All of the trouble code Numbers.
Maybe try disconnecting the IAC, the engine may idle rough or stall, but you can keep it going with a little accelerator pedal, then see if it'll move wihout stalling.
If not, switch the OD Off & shift into all gears.
If no joy, I'd suspect the torque converter clutch is locked up, thats sorta like leaving a straight drive in gear when coming to a stop.
How is the tranny fluid condition????
Well we don't have enough vehicle history to jump to that conclusion just yet & I'm not a tranny guy, I know just enough about em to be dangerous!!!! lol
You likely need input from a Ford tranny tech.
Is the OD light on, or flashing????
Did you ever try turning the OD OFF, by pushing the switch on the end of the shift lever, until the OD Off light in the dash comes on, then trying to shift into gear????
This is supposed to deactivate the torque converter lock up solenoid/clutch, so maybe exercising the OD switch would wake something up?????
Has this vehicle had any tranny problems or repairs before this event????
