93 f150 clutch
Old 06-20-2010, 07:15 PM
rmalottwtes30's Avatar
rmalottwtes30
rmalottwtes30 is offline
93 f150 clutch
helped a buddy replace the clutch in his 93 f150 4 speed transmission with a 4.9. The retaining clip that holds the slave cylinder broke, what is the part number for this? Also we rigged it up until we can get the part, the slave cylinder moves a little would it cause it to shift hard? We can put it in first and will grind, it will do it to any gear but if you put it into 2nd gear first then it will go into any gear.
Part number for the retaining clip is?
also how do you bleed this thing, it does not have a bleeder on the slave cylinder?
Thanks guys!
Old 06-26-2010, 06:57 AM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
I'm not sure about a part number, but I think to bleed the slave requires manually moving the slave cylinder held vertically with the hose end up to push the air up to the master cylinder. If the slave is moving at all in its mount, it could definitely keep the clutch from releasing fully (as would air in the system) which would cause difficulty getting it to go into gear.
|WYG|SS
11-16-2015 06:54 PM
93tankus
11-02-2007 08:16 AM
hoxiii
06-13-2007 04:35 PM
Richard Forster
10-30-2006 11:35 PM
BernDog
05-30-2006 07:29 AM
Quick Reply: 93 f150 clutch
