Engine backfires through carb and wont start
Old 06-20-2010, 02:51 PM
Truckmano5's Avatar
Truckmano5
Truckmano5 is offline
I have just reinstalled my distributor after some engine work. All the engine will do when i try to crank it is pop and huff through the carb. Is the dizzy 180 degrees off? I have the engine at what I believe is TDC.
Old 06-20-2010, 03:58 PM
4x4 Bart's Avatar
4x4 Bart
4x4 Bart is offline
I would try moving the distributor 180. Make sure at TDC the rotor is pointing to #1
Old 06-20-2010, 07:19 PM
four.six's Avatar
four.six
four.six is offline
Yep sounds like your 180 out. It's trying to fire on the intake stroke.
Old 06-20-2010, 11:06 PM
Truckmano5's Avatar
Truckmano5
Problem solved. One hundred and eighty degrees around and down the road I went. Thanks a ton fellas.
tank_153
12-22-2015 11:06 AM
Jagesage
08-13-2015 02:59 PM
pud
Alternative Fuels, Hybrids & Mileage
07-10-2006 03:17 PM
serving_time
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
02-09-2005 02:51 AM
truckmano5-2
05-04-2004 12:56 AM
Quick Reply: Engine backfires through carb and wont start
