why wont my propane cheater hose work??
Old 06-14-2010, 06:41 PM
black water's Avatar
black water
black water is offline
can any one help me out as to why my propane "cheater hose" wont let any fuel into my tank. it was a pain in the *** finding the cheater hose and now my trucks still sitting in spot of my yard that i cant really get anything to pull it out with and its out of fuel and i gotta moce that dirty S.O.B.
any help would be much appreciated thanks!!
Old 07-04-2010, 04:23 PM
tedtheo's Avatar
tedtheo
tedtheo is offline
You need to turn your 20lb tank upside down so the liquid will flow through. If you have a newer style tank with the saftey shut off it might close off the flow when you turn it upside down. It will be a fairly slow process since it needs a higher pressure in your little tank to force the liquid into your vehicle tank.
Old 07-05-2010, 05:53 PM
monckywrench's Avatar
monckywrench
monckywrench is offline
OPDs do hold the valve closed when inverted (which is also why they should be transported in the upright position, so the bottle can vent if overpressure occurs).
A cheater to fit the liquid line off a forklift cylinder would do the job if that is an option.
Dustin 5286
Modular V8 (4.6L, 5.4L)
10-30-2016 03:53 PM
24 Carat
03-27-2016 07:58 PM
black water
06-16-2010 12:57 AM
77f250400
06-11-2010 07:55 AM
pvatki
1983 - 2012 Ranger & B-Series
09-24-2009 11:21 PM
Quick Reply: why wont my propane cheater hose work??
