Modern tire equivalent for 6.50-16?
My info shows a 6.50-16 as 6.75" wide and 29.92" tall. On a 16" rim a 225/75 r 16 is a close match.Try this site to compare tires www.miata.net/garage/tirecalc.html
Bob
Bob
Here's the tire calculator I like to use. It's not as fancy with the Java graphics like Bob's, but they're really not necessary. You can also go directly to the search for tires link and find out what is available, with prices, in your chosen size.
Tire Size Calculator - Discount Tire Direct
Bob
Bob
Also, I thought the 6.50 in my current tire size was literally 6.5" wide, is that not right?
I guess I should have asked some questions first, are you looking to keep your gearing the same (speedometer), looking for original look,are you set on using stock rims? The answers can be more exact with more input.The truck will accept (clearance) the size I gave.You can go with 15" rims and open alot more options.
Bob
Bob
Looking through my National Wheel and Rim Association manuals, your 4.50" rim is spec'd for a 6.50 tire. On that narrow rim you'd be looking at a modern 175mm width. It would take a 6" rim to properly fit a 215 width. To my mind you're better off staying with a modern 6.50 x 16" tire like would be available from Coker, Universal, Lucas, or Miller. Stu
Bob
Bob
Jersey devil
17
04-24-2017 08:10 AM
BennyS
03-29-2016 02:20 PM
Scotty's 52 F3
18
09-18-2015 06:13 PM
KASTENJ
09-13-2010 11:01 PM
