Idaho Chapter Idaho Chapter
Join Chapter, Leader:
IS the motor blown?
Old 06-07-2010, 03:32 PM
TecCrash's Avatar
TecCrash
TecCrash is offline
IS the motor blown?
That is the question! Hi all! Went out last Sat am to start the truck to warm it up so I could change the oil. Went inside to grab a sandwhich and when I came back out it sounded like a cummins and it was puking oil. I needed to unload some hay out of it so I fired it up a few minutes ago and now all I have is a slight tick in the valve train and I still have tons of power. What do you guys think?
Old 06-07-2010, 05:24 PM
im2tall33's Avatar
im2tall33
im2tall33 is offline
hmm?? i havent heard of that b4.. I would post this in the motor section that is valid to your motor..
Old 06-07-2010, 05:27 PM
im2tall33's Avatar
im2tall33
i posted a link to this for you in the v8 section.. hopefully they can help you out
Old 06-07-2010, 06:39 PM
TecCrash's Avatar
TecCrash
TecCrash is offline
Thanks, I haven't had a chance to dive into yet .... I need to get a starter in my project chevelle so I have SOMETHING to drive tomorrow..
Old 06-30-2010, 01:13 PM
TecCrash's Avatar
TecCrash
TecCrash is offline
OK... so here's the update. I found that the oil was puking from a bad oil sender unit but only under load. As long as I didn't rev it too high or haul a load it would hold pressure. When I loaded it up it would puke so much that I wasn't getting enough pressure to supply the motor with oil. Anyway once I changed that out all seems ok, well kinda .... now I'm lacking power big time, so it's off to diagnose that problem
Thanks!
Old 06-30-2010, 01:19 PM
im2tall33's Avatar
im2tall33
good..luck sorry for the misfortune
