Ignition only firing after letting off the key
Hey all,
My brother's having some issues with the 1986 carb'd 351 in his Bronco. Sometimes it just won't fire up, and will crank and crank without any results until the moment he'd stop trying to start it.
He said he pulled the wire off of the coil and watched the end while someone else tried to start it and there wasn't any spark until they let off the key, and then it would spark once.
Any ideas what may be causing this? Ignition module? Coil? Starter solenoid? Etc.
Thanks.
Thanks.
Yup, IF you have the DuraSpark II ignition system!
When you turn OFF the DuraSpark II ignition system, it fires one time. It really helps in troubleshooting.
Disconnect the plug to the distributor, and ohm out the pickup coil that is inside via the wires.
I went out to the garage and dug up an old intermittent one that caused me problems on a Ford wagon years ago. It has Purple, Orange, and Black wires on it. The Black is a ground, the pickup's coil is the Purple and Orange wires, at least on this one.
If it measures open, that's the problem. Pretty easy to fix with the distributor in place. Remove roll pin holding in the reluctor (the toothed wheel) carefully, pull off the reluctor, then remove snap ring that holds the pickup coil/magnet assembly down. at least that is what I remember from about 15 years ago!
The pickup coil is inside the distributor. It's wires extend out of the distributor to a plug. Unplug it, and check the resistance into the distributor side. You are trying to determine whether the pickup coil still has continuity (good), or is open (deceased).
If it is open, I gave steps how to remove the old one. And as they say, reassembly is the reverse of disassembly.
Here is a link to a pic of the pickup coil. It is an assembly consisting of a pickup coil and a magnet. It replaces as one part.
More Information for STANDARD MOTOR PRODUCTS LX204
From a 1982 Ford manual, the pickup coil should have resistance in the range of 400 - 1300 ohms if it is good. I can't measure my old one, 'cuz it's open. Anywhere in or near that range is good.
1982ford econoline van
[/B]the van i have does not have reluctor in the distribator
Thanks for the response.
Are you talking about the distributor or the ignition control module in your description above?
So, if it measures open, what does that mean?
Open up the distributor, remove reluctor, etc (BTDT), and then what?
I wasn't sure if I missed something.
I small glitch in the icm.
When "letting off key" you "only get fire to coil"
everyone has good points as to fix this problem and I commend them!
there however is another way that might have made
"this happen"
bought an ignition control module for my 83
still had the no power at start problem,then realized it!
the red-run wire. And the white -start wire were backwards!FROM THE FACTORY. a motocraft one at that...sos what do I do?
I spliced and put the colors back.
new problem..
won't start at all.
(old owner tried fixing this problem before)
long story short fellas..and gals.
don't switch the acc/run wire and the START wire. Only half of the system works then.
you see when you put your switch to START ,accessories are CUT OFF.
put lower column BLADE SWITCH CONNECTOR WIRES BACK TO FACTORY. And make sure your NEW module's wire colors match at the plug -ins.
thank y'all, have a nice day!
"this happen"
new problem..
won't start at all.
hharris8
141
09-22-2016 04:43 PM
Mellis4693
06-27-2016 07:28 PM
Aircraft Tech
06-23-2016 10:50 AM
