HELP! What is another name for the Fuel Filter Restriction Sensor
1997 F-250 PSD
I found my fuel filter restriction sensor leaking this evening! Is there another name for that part so that I can find it at advance auto, autozone, or napa? I have those stores local, but the dealership here does not carry parts. The leak is about a drop every two to three seconds, so it's a decent leak.
I gotta drive the truck like that tomorrow, and I'll fix it in the evening!
Thanks auto gawds!
Tim
Thanks auto gawds!
Tim
Thanks guys, I cannot justify spending the $70 from a stealership for the part and shipping. Today, I installed a 3/8" brass pipe pung/end cap into the space. I dont remember the thread pitch, but it was either 18 or 20 tpi. The pipe bung was a whopping 37 cents. I might put the right part in eventually, but probably not. I'm a cheap azz.
(not so)advance auto, autostoned, and crapa could not get me a new sensor, no matter what i called it. Such is life.
Thanks all!
Thanks all!
Fuel Filter Vacuum / Restriction Sensor
Seriously? I can just plug the hole and move on with my life?
What are the downsides of just plugging the hole and moving on, instead of buying and installing a new fuel filter vacuum switch or fuel filter restriction sensor, or whatever it's called?
Thanks,
Dick
Thanks,
Dick
Thanks
OK, 1/8th inch 18 or 20 threads per inch, right?
Anything special as a washer when I plug this? What length should I use? The thing is dripping 1 per second now, and I'd like to get 18 MPG on my 1996 f-250 power-stroke that has 291,000 miles, instead of the 16.5 I'm getting now. Of course, when I change the gears from 4:10 that may help, as will adding a Banks programer... anyone have any other ideas?
Thanks,
Dick
Thanks,
Dick
