1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Where the heck is the Mega Fuse pics needed.
Old 06-05-2010, 04:18 PM
Gmeanie's Avatar
Gmeanie
Gmeanie is offline
2001 F250 5.4 V8 4x4.
I have had my alternator tested and it was OK.
Bought a New battery costing me 100.00.
Even tried a new alternator and the battery light still stays on.
I read about the Mega Fuse and for the life of me I can not find it.
Passenger side firewall I see nothing.
I searched the whole engine bay nothing.
Looked in the covers can't find anything that looks like it.
Help me pics needed.
Old 06-05-2010, 11:05 PM
Surge08's Avatar
Surge08
Surge08 is offline
should be inline with the alternator or along the fire wall
Old 06-06-2010, 06:47 PM
Gmeanie's Avatar
Gmeanie
Gmeanie is offline
I looked there and see one line marked FUSE but there is no mega fuse on it. Goes from the Alternator then branches to two grey wires connecting to the starter relay.
Old 06-06-2010, 08:57 PM
gearloose1's Avatar
gearloose1
gearloose1 is offline
Do alternator diagnostics, voltage tests.
Come back with results.
Old 06-07-2010, 12:27 AM
Surge08's Avatar
Surge08
Surge08 is offline
The one marked fuse is the Mega if memory serves me correctly
Old 06-07-2010, 01:44 PM
Gmeanie's Avatar
Gmeanie
Gmeanie is offline
I tried 3 new alternators and have had mine tested at autozone and it checks out fine.
The mega fuse came in today hopefully I can find where it goes otherwise I have no clue why the light flickers and doesn't charge and stays on sometimes too.
Old 06-07-2010, 05:49 PM
Wagion's Avatar
Wagion
Wagion is offline
Bad ground?
Old 06-07-2010, 10:30 PM
hargrett's Avatar
hargrett
hargrett is offline
You may have a fusible link. Sometimes two fusible links from the alternator's main charge/battery cable. May be gray in color labeled with 12 or 10 gauge. The two gray wires you mentioned going to the starter relay.
JJH
Old 06-08-2010, 11:46 AM
Gmeanie's Avatar
Gmeanie
Gmeanie is offline
cleaned the ground and fuseable link tested fine at autozone.
guess i have to send it in
Old 06-08-2010, 01:58 PM
hargrett's Avatar
hargrett
hargrett is offline
Use a Volt meter to check your voltage, when the truck is running voltage will be close to 14+ volts. If you get 14+ at the battery the alt is good. The wire going to the battery light may have a short or broken. One of the smaller wires from the alt goes to the battery light.
Old 06-08-2010, 11:31 PM
Surge08's Avatar
Surge08
Surge08 is offline
This may be an dump question but have you checked your battery light on the dash to see if its burned out or checked the 10 mini fuse under the dash?
Old 06-11-2010, 08:27 PM
Gmeanie's Avatar
Gmeanie
Gmeanie is offline
Just thought I would let everyone know what happened so if they have these problems.
I brought it to a FORD shop and even thou I told them I tried 4 different Alternators and had mine tested they insisted it was the aftermarket alternators not outputting enough for my full power truck.
So I wait and they had to order a FORD alternator. It finally comes in and guess what? It wasn't the Alternator. So They take the inline FUSE out even thou it tested good at autozone and ford themselves from what I seen only some of the wire's inside where broken. Maybe not getting enough juice because of that? But of course when All is said in done they still insisted I needed a new Alternator so the final bill was $430.00!
What is the proper way a checking an inline FUSE if you don't have test gear? Hell the test gear didn't even help this time around it was saying the FUSE was fine.
So when it was said in done - Alternator and inline Fuse.
Old 06-11-2010, 09:22 PM
gearloose1's Avatar
gearloose1
What is the proper way a checking an inline FUSE if you don't have test gear? .
The only sure way to check a fusible link (and many kinds of fuses), is to replace it.
Period.
Much simpler than rigging up a tester.
Oh.. I would concur with them re Ford alternator.
Old 10-02-2013, 04:35 PM
hoytaray's Avatar
hoytaray
hoytaray is offline
kinna sounds like you got taking by dealer, but what else ya gonna do! makes me wonder if the inline fuse was just bad connection or maybe it was loose enough inside that it wouldnt work but showed good at auto part store. I am trying to find a solution to mine right now. see if you can help
Old 10-02-2013, 05:24 PM
Firekite's Avatar
Firekite
Firekite is offline
I had an alternator go out on my '07 6.0L, and the slightly higher amp replacement I got from O'Reilly would result in a flickering battery light and eventually battery problems. Turns out the alternator wasn't making the proper power, some manufacturing defect, so they swapped it out for another one. That one was solid, and I never had any problems with it again, though I traded it in and who knows now.
Your case was a little more difficult to nail down, as it turns out, but it's not true that aftermarket alternators can't produce enough power. If you get the wrong model, then yeah, that can be a problem. Or if the alternator is defective, then that is what it is. In my case, the alternator was capable of making MORE power than the factory one.
Rusty_S
Electrical Systems/Wiring
03-21-2016 03:53 PM
JoeJN
2004 - 2008 F150
11-14-2015 08:52 AM
Georo
1997 - 2003 F150
04-12-2015 06:53 PM
GOVTMOD
22
08-04-2013 06:19 PM
RoyalFord
1997 - 2003 F150
01-15-2012 11:38 AM
Quick Reply: Where the heck is the Mega Fuse pics needed.
