Torque specs for flywheel and pressure plate???
Old 06-04-2010, 12:15 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
Anyone got these torque specs for the flywheel and pressure plate? i googled and ran a quick search on here. i got the stock flywheel getting turned today while i'm at work so when i get off i can go get the flywheel and install my new Centerforce dual friction clutch and flywheel. Thanks guys!
Old 06-04-2010, 01:18 PM
LawF250's Avatar
LawF250
LawF250 is offline
When I did my clutch last year (351w) I just used the standard torque spec "RFT" (Really F*@#ing tight) lol.
I think the real torque spec for the flywheel is right around 50-60 ft. lbs and the pressure plate depends on your clutch size
if i remember correctly 10 inch clutch is 15-20 ft lbs and the 11inch is 20-29 ft lbs or something close to that, I could be wrong though
Old 06-04-2010, 01:44 PM
strokin'_tatsch
it's an 11" clutch. i shoulda put all that in the original post. LoL.
Old 06-04-2010, 04:52 PM
Duramaxfanatic1's Avatar
Duramaxfanatic1
Duramaxfanatic1 is offline
if anyone could confirm i have the same shtuff and would like this to be the last time i have to drop my tranny for a while
Old 06-07-2010, 09:01 AM
strokin'_tatsch
i found 2 different torque specs on the pressure plate. i found 12-24 ft/lbs on a different website today, but on Friday i searched for a couple hours after this thread and found 20-29 ft/lbs a couple times. i did mine to 29 ft/lbs just for fun. it shouldn't make too much difference between 20-29 ft/lbs just as long as they are all the same torque so that the pressure plate fingers are all at the same distance from the throwout bearing.
Flywheel-- 75-85 ft/lbs
pressure plate-- 12-24 ft/lbs or 20-29 ft/lbs????
Old 02-21-2011, 05:12 PM
big six shooter's Avatar
big six shooter
big six shooter is offline
speaking of specs...anyone know the stock clutch holding power, preferably in torque
Old 05-13-2012, 05:51 PM
fstbck1970's Avatar
fstbck1970
fstbck1970 is offline
dont mean to jack the thread but how do you figure out what size the clutch is
Old 05-13-2012, 06:50 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
What engine?
Old 05-13-2012, 07:06 PM
fstbck1970's Avatar
fstbck1970
its a 300 w/ the mazda tranny
Old 05-13-2012, 07:35 PM
Diesel_Brad
O christ. I didnt realize you brought up a dead thread.
To find out clutch size you have to measure it
Old 05-13-2012, 07:41 PM
fstbck1970's Avatar
fstbck1970
haha thats google for ya.
and yeah thats obvious. i was wondering if there was a way to know without droppin the tranny, and make sure the right size is in it. i dont trust previous owners haha.
Old 09-25-2016, 12:22 PM
89scott's Avatar
89scott
89scott is offline
dead thread.. dont care.. cause this pops up on google. I ordered a 10" clutch, dropped tranny and it was an 11" clutch. For $55 and the ease of the job with my new transmission jack, I'd of bolted a 10" for a few months but it wouldn't bolt up.
Not sure how to find out 10 or 11 without dropping tranny.
pascalhorse
01-21-2018 09:57 PM
PatrickFord1986
10-06-2017 07:22 AM
F-1
01-18-2017 07:42 PM
HT32BSX115
05-04-2016 11:06 PM
Fordman7992
02-03-2016 08:22 AM
Quick Reply: Torque specs for flywheel and pressure plate???
