79 C6 Transmission fluid Question
Old 05-29-2010, 10:26 PM
Roelito78's Avatar
Roelito78
Roelito78 is offline
Wow, lots of great information! So, I guess I have two choices. One, take a guess and go with the mercon and cross my fingers hoping type F is not in the converter. Two, drain the converter if I can find that plug. Looking at my truck this morning I saw the inspection plate which is about 3-4 inches long and about 2-3 inches tall. Is this the dust plate? Or is the plate the larger piece which covers the entire flywheel? Sorry for all the questions guys but I truly appreciate the input.
Old 05-29-2010, 10:44 PM
phatjack81's Avatar
phatjack81
phatjack81 is offline
Yep, the small one with two small bolts. Take that off and you'll be looking at the flex plate which the Torque Converter is bolted to. There will be 4 nuts holding the TC on and beside one of them there will be hole and that's where the drain plug is, I think it's a 3/8" or 7/16" head. You'll have to have someone bump the motor around till you see it. And if I'm not mistaken a a total drain and refill is a little over 13 qts.
Old 05-29-2010, 10:50 PM
Roelito78's Avatar
Roelito78
Great! Thanks phatjack, I will look into it tomorrow. I guess that is probably a better way to do things instead of just guessing. When you say bump the motor you mean try to start the truck correct?
Old 05-29-2010, 10:56 PM
phatjack81's Avatar
phatjack81
Yep, keep clicking the starter till you get the drain plug on the bottom or as close as you can.
Old 05-29-2010, 11:00 PM
Roelito78's Avatar
Roelito78
Thanks a lot! Will try it tomorrow hopefully this will be one more task out of the way. Getting closer and closer to the paint job! cant wait
Old 05-30-2010, 07:27 PM
Roelito78's Avatar
Roelito78
Ok , I drained my torque conerter today. Like you guys mentioned it was a piece of cake. Now, the question is, how many quarts of tranny fluid do I need to purchase? Will the torque converter fill on its own once I start filling the tranny with the fluid? I have decided to go with the Dextron 111/Mercon fluid. hopefully this works!
Old 05-30-2010, 08:02 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Probably should get around 14 quarts, give or take 1.
Are you using only the stock tranny cooler in the radiator or are you also using an inline as well? Probably need to add about a quart for each external cooler if you have one.
Which, I should mention, is a good idea to have anyways. The cooler you can get the fluid the happier the transmission will be.
I use dual Thinline coolers, and it is pretty difficult to get the tranny temp over 170, even on a 95 degree day hauling rock.
Josh
bmuhlbach's Avatar
bmuhlbach
bmuhlbach is offline
put 9 quarts in and adjust from there it will take 12-13 quarts
Old 05-30-2010, 08:07 PM
Roelito78's Avatar
Roelito78
Ok will do, I will start with 9 quarts. I believe the truck only has one cooler which is part of the radiator but no inline cooler. How much are those inline coolers? Are they easy to install?
Old 05-30-2010, 08:11 PM
Bullitt390's Avatar
Bullitt390
Super easy and most are under $40.
Josh
Old 05-30-2010, 08:14 PM
Roelito78's Avatar
Roelito78
Thanks Josh! I will definately look into it. Cant wait to get this bad boy on the road again!
Old 05-30-2010, 08:19 PM
Roelito78's Avatar
Roelito78
Time to enjoy our freedom! Thanks to all the men and women who serve or have served to protect our country! God Bless!
  #28
Old 08-23-2010, 09:44 PM
79f100trucker's Avatar
79f100trucker
79f100trucker is offline
79 F100 Ranger Slipping tranny overheating..
Hello gentlemen! I have a 79f100 ranger with original C6 transmission,but some times it slips, Recently it overheated after speeding while climbing a hill would it be a good idea to change the tranny fluid and filter or will need to be rebuilted? I hope you experience guys can help me with this issue.. thank you
  #29
Old 08-23-2010, 09:55 PM
Bullitt390's Avatar
Bullitt390
Cheap insurance to go ahead and change the fluid. Be sure to drain the torque convertor as well to try and get as much old fluid removed as possible.
Josh
  #30
Old 08-23-2010, 10:14 PM
79f100trucker
Question
If i drain The convertor how do I refill it? and what are the possibilities of fixing my tranny if I just change fluid and filter will I notice improvement shifting?
Quick Reply: 79 C6 Transmission fluid Question
