E350 tow pkg and rear gear questions
Hello
I just got this 98 E350 Chateau passenger van with the V-10 and just assumed it had a towing package. Today I looked and saw what appeared to be a trans cooler mounted in front of the radiator but I wanted to verify which tow package it has (std or hd?). It pulled my TT and I noticed that the rpms were much lower in OD at highway speeds (by sound no tach) than my Ex with the 4.30 so I wanted to know how to tell which rear gear ratio it had off of the VIN or gear code. The VIN is 1FMNE31S7WHA15450. There is a second bar of codes and under Axle is says 34. Where can I post to get an OASIS for this van?
Also does anyone know the approx empty weight of a E350 with factory seating (4 capts 1 bench) and options?
Thanks
Joe
Thanks
Joe
If you Google axle codes Ford E350, you get this...
From the '04 Service Manual
AXLE CODES
19 — 3.55 ratio, non-limited slip (Visteon)
22 — 4.10 ratio, non-limited slip (Dana)
24 — 3.73 ratio, non-limited slip (Dana)
32 — 4.10 ratio, non-limited slip (Dana)
34 — 3.73 ratio, non-limited slip (Dana)
35 — 4.09 ratio, non-limited slip (Dana)
39 — 3.55 ratio, non-limited slip (Dana)
52 — 4.10 ratio, non-limited slip (Dana), dual rear wheels
56 — 4.10 ratio, non-limited slip (Dana)
82 — 4.10 ratio, non-limited slip (Dana)
83 — 4.56 ratio, non-limited slip (Dana)
84 — 4.88 ratio, non-limited slip (Dana)
85 — 5.38 ratio, non-limited slip (Dana)
B4 — 3.73 ratio, limited slip (Dana)
C2 — 4.10 ratio, limited slip (Dana)
B2 — 4.10 ratio, limited slip (Dana)
C4 — 3.73 ratio, limited slip (Dana)
C5 — 4.09 ratio, limited slip (Dana)
C9 — 3.55 ratio, limited slip (Dana)
E2 — 4.10 ratio, limited slip (Dana), dual rear wheels
E6 — 4.10 ratio, limited slip (Dana)
F2 — 4.10 ratio, limited slip (Dana), dual rear wheels
F3 — 4.56 ratio, limited slip (Dana), dual rear wheels
G4 — 4.88 ratio, limited slip (Dana)
G5 — 5.38 ratio, limited slip (Dana)
H9 — 3.55 ratio, limited slip (Visteon)
TRANSMISSION CODES
5 — Four-speed automatic overdrive (4R75W)
B — Five-speed automatic overdrive (5R110/Hi-Torque), diesel
E — Four-speed automatic overdrive (4R100)
U — Four-speed automatic overdrive (4R70W)
AXLE CODES
TRANSMISSION CODES
shotskie
38
06-28-2016 10:47 PM
sandi_k
25
05-21-2010 06:41 PM
