Maryland Chapter Join Chapter, Leader: BPofMD
Headlight Restoration kit
Old 05-26-2010, 05:59 AM
Blade79's Avatar
Blade79
Blade79 is offline
Question Headlight Restoration kit
Has anyone ever used that headlight restoration kit and if so what was the out come? Good, bad, pictures?
Thanks,
Rick
Old 05-26-2010, 08:43 AM
BPofMD's Avatar
BPofMD
BPofMD is online now
Received 1,081 Likes on 983 Posts
I used the Meguires plastic polish with a pad and my electric drill....rotating SLOW - if real bad, use wet #1500-2000 sandpaper first. Used this on my '97 Lincoln. Might have to retouch about once a year. Looks crystal !
Old 05-26-2010, 08:47 AM
Blade79's Avatar
Blade79
Blade79 is offline
Thanks Bud. I am hoping to give it a try this weekend if I get a chance.
Old 05-26-2010, 04:15 PM
66fdtrucknut's Avatar
66fdtrucknut
66fdtrucknut is offline
I just won a restorer kit as a door prize a wynn's I believe. Haven't tried it yet though.
Charlie
Old 05-28-2010, 12:20 AM
80351's Avatar
80351
80351 is offline
Never touched them with sandpaper and actually have done all mine with my buffer and a little bit of polishing compound
Old 05-28-2010, 09:20 AM
BPofMD's Avatar
BPofMD
I see that Harbor Freight has a H/L Restore Kit on sale for 9 bucks. Gotta use your drill. Can't go wrong with that. You'll need the coupon. Go to: 12 Minute Headlamp Lens Restoration Kit
Old 06-14-2010, 06:47 PM
DAFBFD58's Avatar
DAFBFD58
DAFBFD58 is offline
I used Meguires for mine. Came with the buffer adapter. Worked great on mine
Old 06-15-2010, 11:33 PM
DRangerMike's Avatar
DRangerMike
DRangerMike is offline
https://www.ford-trucks.com/forums/9...ml#post8197259
Pictures of my headlights with the before and after. Used the restoration kits that come with the drill attachment.
Old 07-18-2010, 12:05 PM
Blade79's Avatar
Blade79
Blade79 is offline
Update: I finally got around to working on the heaqdlights today. I have to admit I went the cheap route. I took a piece of 1500 snadpaper and wetsanded them and then polished them here are the before and after pics.
Old 07-18-2010, 03:24 PM
jr32560's Avatar
jr32560
jr32560 is offline
hey they turned out real good-gonna have to give that a try
Old 07-18-2010, 05:44 PM
dustybumpers's Avatar
dustybumpers
dustybumpers is offline
drill a small hole inside, near the bottom on the right light, it will make the condensation go away, and bulbs will last longer. lights look good. want to do mine? I'll let cha.might burn something on the grill while you work for payment.
Old 07-18-2010, 07:34 PM
Blade79's Avatar
Blade79
Blade79 is offline
Thanks. Hey Charlie, how about you replace my rocker arms amd i'll do you headlights. I might even do the tail lights too.
Old 07-18-2010, 07:38 PM
dustybumpers
I'll help with the rockers, just to help, you don't want to do my lights, I have too many trucks.
Old 07-18-2010, 07:39 PM
Blade79's Avatar
Blade79
Blade79 is offline
It only took me about 5 min total for each light.
Whitey Ford
07-20-2014 03:03 PM
Gage2502
07-07-2012 09:49 PM
1992FordF150Custom
05-24-2012 12:35 PM
BAD RONALD
Aerostar
16
02-12-2012 08:38 AM
Gage2502
34
03-28-2011 08:01 PM
Quick Reply: Headlight Restoration kit
