First post---Hello all..2007 expedition lim. EL
Hi everybody, brand new user here. I have been using this site quite often as a resource since I bought my new 2007 expedition el limited (not even a month ago). I have a bunch of questions since this is my first Ford vehicle. Because of this site I learned about reprogramming the trans and now it runs much smoother.
a couple initial questions: am I the only one that is bothered by the noisy plastic on the middle counsel? Is there a fix?
Next, I feel like I'm leaning and pulling (it is pulling for sure) to whatever side of the rode I'm on. Is this because the truck is so heavy?
do transmissions warm up?
I appreciate any comments and look forward to talking
J
J
Welcome Unreal, we're glad to have you here. I don't have the same model as you so I can't comment on the console. The pulling could be caused by many things, unequal tire pressure, alignment, etc, but you said both sides of the road. If the road leans right, the truck is gonna want to go right and left if the road slopes to the left.
Finally, yes transmission do warm up, in fact they can get quite hot especially when pulling a load and excessive heat is usually the cause of a tranmission's early demise.
thanks
Thanks for the response. I do feel like the leaning/pulling is based on the road but it just seems to be much more drastic and noticable than my 07 silverado. no biggy I guess.
as far as the tranny question, I was just wondering if a warmed up tran runs smoother than a cold one. Like I said, this is new to me and I have no mechanical experience. I just really enjoy reading posts from people who know their stuff and try to keep up. and even learn something along the way.
welcome. i'm new to the site to.
i just got my first exp about 6 weeks ago. it's a 2007 EL EB.
i've never noticed anything about the console, but i did have to realign both front door. the pass door wasn't sitting flush and the drivers door had a bunch of wind noise. i adjusted both doors and put some weatherstipping/foam tape on the inside (top) of the drivers door and it fixed that problem.
i would check the tires and alignment on the car to be safe. i've never noticed any pulling on my. it drives pretty straight and true. of course brand new tires were put on when i bought it.
i've got factory 20's on my EB. i went with it because i like the two-tone leather and the two-tone paint versus the limited. it drives really smooth. plus, it's got all the options that i wanted.
is your plastic lid squeeking? you might try lining the underside with some black foam tape. that way, when it's closed, it's some cushion under it and it's not plastic on plastic. just an idea.
i've never noticed anything with the wiper pulse during a stop.
my carpet is black with the catch-all black floor mats.
there's not a lot to move around in the console, so try the tape and see. it's usually with the weatherstripping in hardware stores.
my transmission is fine. it didn't need any adjustment and doesn't jerk at all. if yours does, disconnect the negative terminal on the battery for awhile to reset the computer. i've heard that helps. i didn't have to do that, but that's what i've heard. mine is smooth sailing.
nice
nice...it sounds like you got a good one, how many miles?...I had my trans reprogrammed / flashed last week and it improved the trans a lot. It's smooth, just not as smooth as my silverado, but it is 6000 lbs.! I gotta get some of those catch all mats. I still have the cheap ones that came from the dealer. Do you have some pics of your ride? I'm not sure if I can upload pics because of my basic membership.Do you know if I can replace my running boards with step up bars?
i really like it so far. it's got about 40k on it. these are big, heavy rigs, but it's still pretty smooth. i don't have any pics right now.
you should have the power running boards on the limited, so wouldn't recommend changing them, but i suppose you could if you wanted to. that's another reason why i went with the EB, the running boards aren't power. that's a cool feature, but i wouldn't really use it.
My 07 Limited EL doesn't have the power boards either. I bought mine used last year. It's a "basic" limited withoutt he 20" option, no nav, and without the power 3/4 windows and roof. But.... it only had 14k on the clock and it was more than worth the price I paid for it after trading the 03 Screw I had at the time.
If you're in Michigan I would imagine that your road crown is a few degrees more than what we have here in NH. As long as your tire pressures are accurate and similar across the 4 wheels and your alignment is in spec, I'll wager that your crown has more to do with a slight pull than anything. A good alignment shop in your area could adjust your specs to the limits of factory settings to help alleviate your drift, or go just outside them if you're willing to complain a little bit.
As far as your interior noises, I have similar issues. Right now it's warmer and getting more so up here in NH so the noises are no where near as pronounced as they were in the middle of January. I just chalk it up to the cheapo plastic Ford used "much to liberally" throughout their interior on these "more expensive" SUVs. If/when it starts to REALLY bug me, I'll get some felt tape and tear everything apart and tape the bejeezus out of it till it's nice and quiet like.
thanks
