302 Water pump
Old 05-16-2010, 11:47 PM
dmt_73ford's Avatar
dmt_73ford
dmt_73ford is offline
Question 302 Water pump
I am a new member to FTE but have been a follower for a short time, this is my 1st post. I have a 73 F100 with a 302 & C4 auto trans. The tranny needs a rebuild so I havent driven lately and has sat for about a year since I last started her up. I decided to try to get her running again but have hit a few snags. I had to replace the fuel pump to get her started. Then with the first startup she dumped a load of water. I picked up a new water pump and got the old one out. Then I discovered a hole above the upper right water passage on the block. I have a feeling this is a bad sign. Has anyone seen this before? Does this mean my block is rotted?
Old 05-17-2010, 12:05 AM
JAYS69F100's Avatar
JAYS69F100
JAYS69F100 is offline
From what I can see, it looks like your timing chain cover is corroded away. The aluminum piece between the water pump and block.
Old 05-17-2010, 02:10 AM
RVDan's Avatar
RVDan
RVDan is offline
Nope, just your timing cover is rotted
Old 05-17-2010, 11:12 AM
eric138's Avatar
eric138
eric138 is offline
I had the exact same problem and just patched it with jb weld. It is probably not the best solution but the only thing I could think of other than replacing the whole timing cover. It has lasted about a year and a half like that with no problems. There is not much pressure behind it. To do it I put a little piece of wax paper in the vent then covered the outside with the jb weld let it set and took the wax paper out. Quick Fix.
Old 05-17-2010, 06:19 PM
dmt_73ford's Avatar
dmt_73ford
Thanks! I will probably pull the motor, its a project truck anyway.
Old 05-17-2010, 09:04 PM
dkf's Avatar
dkf
dkf is offline
Looks like you have a lot of degreasing to do.
Old 05-17-2010, 11:08 PM
dmt_73ford's Avatar
dmt_73ford
Anyone have any idea how much time and hassle I have in replacing the timing cover? Am I going to get into popping the oil pan?
Ya dkf, the grease is everywhere, all my bolts were caked. Its probably going to take me most of my weekend cleaning the grease from the whole underside so I can yank the tranny.
Old 05-18-2010, 12:54 AM
RVDan's Avatar
RVDan
RVDan is offline
Its always troublesome getting the bottom of the timing cover to seal to the oil pan again without loosening off the oil pan
Old 05-18-2010, 08:33 AM
dkf's Avatar
dkf
dkf is offline
The oil pan gasket could more than likely use replacing anyway.
Old 05-18-2010, 11:31 AM
jsutton's Avatar
jsutton
jsutton is offline
Yea, there are four bolts in the bottom of the timing cover that attach to the oil pan. As stated you'll probably have to loosen a few of the oil pan bolts back from the front to get the pan to drop some to let the timing cover bolt holes line up with the ones in the block. The timing cover gasket set will come with new little pieces of cork gasket to replace the part between the timing cover and oil pan. It's just a little triangle kinda piece. I had to do mine when I replaced my water pump because one of the bolts broke off flush with the block. I had to pull the timing cover drill out the bolt and retap the hole.
On the degreasing. Purple power works great!! Buy the big jug and put it in a spray bottle.
PaysonPSD
37
11-12-2018 10:35 PM
mtl93ranger
01-29-2008 09:32 PM
ctch88
1978 - 1996 Big Bronco
08-12-2005 12:10 AM
RedTaurus94
10-20-2004 09:13 PM
Pheonix BlackWolf
Oil & Lubrication
10-20-2002 04:29 AM
Quick Reply: 302 Water pump
