Wheel wobble 89 F150 4x4
Old 05-15-2010, 02:22 AM
jessemace57's Avatar
jessemace57
jessemace57 is offline
I have a short wheel base 89 F150 4x4 with a 351 4" suspension lift and 33"x12.50" tires. Here lately when I hit the brake I get wheel wobble really bad, it also happens sometimes when I hit a bump. I am trying to find out what could be causing this. Lower ball joints are new. Any info would be much appreciated. Also I don't see a steering stabilizer under my truck. Is that normal?
Old 05-15-2010, 06:40 AM
KevinGnWV's Avatar
KevinGnWV
KevinGnWV is offline
The village idiot.
Are you feeling the vibration in the brake pedal or steering wheel?
I would check lugnuts, make sure wheel is tight and centered properly. Aluminum wheels can come loose on their own sometimes. Check your wheel bearings, tierod ends etc.
If you feel a definate pounding in the brake pedal you have a warped brake rotor.
Old 05-15-2010, 07:47 AM
95F350XL's Avatar
95F350XL
95F350XL is offline
If you brake and it wobbles your rotors are def warped, if you are hitting bumps and you get the "death wobble" you might want to look into a dual steering stabilizer.
Old 05-15-2010, 10:43 AM
jessemace57
I feel it in the steering wheel deffinately. I stick my head out of the window and the drivers side tire is shaking side to side like speed wobbling as if it were a cheap crotch rocket. How do I install a stabilizer if mine doesn't have one? Also the inner tie rod bushing doesn't look so hot but both tie rod ends and ball joints look good. Could the inner tie rod bushing where it meets the centerlink cause all that? Thank you all so much for your help and input.
Old 05-15-2010, 10:45 AM
F-350 Mud Digger's Avatar
F-350 Mud Digger
F-350 Mud Digger is offline
Check the ball joints n tie rods. N make sure if you have aluminum rims that you have acorn lug nuts to sit properly n hold it on. Steel wheel lugs will make a aluminum wheel wobble till it will eventually fall off.
Old 05-15-2010, 10:54 AM
jessemace57
I have aluminum rims but I have the lugs with the sleeves so they go between my rim and stud with an accorn head.
Old 06-04-2010, 06:57 PM
F150-4-Life's Avatar
F150-4-Life
F150-4-Life is offline
Jack up the tire...and grab the tire move it left and right and then up and down...make sure its not your bearings...
ford4her
16
08-06-2022 10:58 AM
birddog55
03-16-2021 07:42 AM
Hoots250D
1999 to 2016 Super Duty
08-26-2012 04:29 PM
LT/PM
1997 - 2003 F150
04-15-2010 05:14 PM
tuffguy
07-10-2001 10:59 PM
Quick Reply: Wheel wobble 89 F150 4x4
