Help! Taillights don't work!
Old 05-11-2010, 12:19 PM
Wicked Endings's Avatar
Wicked Endings
Wicked Endings is offline
Hey guys.
REALLY BAD NEWS!
I went and got my license today!
Yay!
I went to bring her down to the inspection place, and noticed that when I turn my lights on.. my tail lights don't turn on.
My brake lights and turn signal lights all work (all on the same bulb) but my tail lights don't work.
Also, when I turned on my lights and turned on the signal switch, it blew the fuse.
I've got to get this fixed within the hour....
HELP!
Old 05-11-2010, 12:38 PM
smashclash's Avatar
smashclash
smashclash is offline
seems to me you have a stripped wire somewhere that's grounding and blowing the fuse. I'd trace the wire and look for any cuts in the rubber insulator.
Old 05-11-2010, 12:56 PM
Wicked Endings
From what I traced, there are no grounded wires except for the actual ground wire...
Old 05-11-2010, 01:05 PM
mytrucksnameisfred's Avatar
mytrucksnameisfred
mytrucksnameisfred is offline
hey wicked i actually had the same problem a couple weeks ago... try wiggling your headlight switch ( i'm willing to bet your running lights dont work either) if that's the problem just make sure you check the lights before inspection and replace the switch after.
Old 05-11-2010, 01:13 PM
TheKirbyMan's Avatar
TheKirbyMan
TheKirbyMan is offline
You could also clean the large "(" shaped wiring harness connector under the hood, near the brake booster. I had problems with my brake light and turn signal on the driver side recently, and by cleaning that connector, it fixed the problem.
Old 05-11-2010, 02:13 PM
bashby's Avatar
bashby
bashby is offline
If you've got a trailer plug check the wiring to it
Jaydoubleyou
06-28-2020 01:11 AM
jstephens2
17
05-31-2013 12:42 PM
cajunhcm
06-06-2010 11:14 PM
micklskot
16
04-04-2009 01:10 PM
barefootstu
Electrical Systems/Wiring
18
01-28-2007 12:42 PM
Quick Reply: Help! Taillights don't work!
